I am going to test the find statement as one of the next things, but first this is the output of my last backup. I removed some lines because they were just repeated with other dblocks or dlists
Both files throwing the error still exist on the system.
2019-11-18 21:00:01 +00 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started
2019-11-18 22:35:12 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2019-11-18 22:37:16 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (23.50 KB)
2019-11-18 22:39:58 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b8e36b4cc806744528068136de4468f9b.dblock.zip.aes (49.80 MB)
2019-11-18 22:40:54 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b8e36b4cc806744528068136de4468f9b.dblock.zip.aes (49.80 MB)
<...omitted...>
2019-11-19 00:39:14 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20191118T210001Z.dlist.zip.aes (62.31 MB)
2019-11-19 00:40:11 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20191118T210001Z.dlist.zip.aes (62.31 MB)
<...omitted...>
2019-11-19 03:29:24 +00 - [Information-Duplicati.Library.Main.Database.LocalDeleteDatabase-CompactReason]: Compacting because there are 5 fully deletable volume(s)
2019-11-19 03:29:28 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Started: duplicati-b8226c47f8aee4f08ae3b7dd32afd72d3.dblock.zip.aes (249.62 MB)
2019-11-19 03:29:34 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Delete - Completed: duplicati-b8226c47f8aee4f08ae3b7dd32afd72d3.dblock.zip.aes (249.62 MB)
<...omitted...>
2019-11-19 03:31:20 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bd72accde1ec049dc99bc453d7d9e92cf.dblock.zip.aes (249.96 MB)
2019-11-19 03:38:59 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Completed: duplicati-bd72accde1ec049dc99bc453d7d9e92cf.dblock.zip.aes (249.96 MB)
2019-11-19 03:38:59 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bd742daac0957402f81e85c35a5be6662.dblock.zip.aes (249.81 MB)
2019-11-19 03:46:36 +00 - [Retry-Duplicati.Library.Main.BackendManager-RetryGet]: Operation Get with file duplicati-bd742daac0957402f81e85c35a5be6662.dblock.zip.aes attempt 1 of 5 failed with message: Invalid header marker
<...omitted...>
2019-11-19 04:10:07 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Retrying: duplicati-bd742daac0957402f81e85c35a5be6662.dblock.zip.aes (249.81 MB)
2019-11-19 04:10:17 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bd742daac0957402f81e85c35a5be6662.dblock.zip.aes (249.81 MB)
2019-11-19 04:18:00 +00 - [Retry-Duplicati.Library.Main.BackendManager-RetryGet]: Operation Get with file duplicati-bd742daac0957402f81e85c35a5be6662.dblock.zip.aes attempt 5 of 5 failed with message: Invalid header marker
System.Security.Cryptography.CryptographicException: Invalid header marker ---> System.IO.InvalidDataException: Invalid header marker
at SharpAESCrypt.SharpAESCrypt.ReadEncryptionHeader (System.String password, System.Boolean skipFileSizeCheck) [0x0004b] in <45c43198e80545aeabaa9b98839b4c7d>:0
at SharpAESCrypt.SharpAESCrypt..ctor (System.String password, System.IO.Stream stream, SharpAESCrypt.OperationMode mode, System.Boolean skipFileSizeCheck) [0x0018a] in <45c43198e80545aeabaa9b98839b4c7d>:0
at (wrapper remoting-invoke-with-check) SharpAESCrypt.SharpAESCrypt..ctor(string,System.IO.Stream,SharpAESCrypt.OperationMode,bool)
at Duplicati.Library.Encryption.AESEncryption.Decrypt (System.IO.Stream input) [0x00000] in <a3217bd0ca2d4a6bb2457ef1971c41fc>:0
at Duplicati.Library.Encryption.EncryptionBase.Decrypt (System.IO.Stream input, System.IO.Stream output) [0x00000] in <a3217bd0ca2d4a6bb2457ef1971c41fc>:0
at Duplicati.Library.Main.BackendManager+<>c__DisplayClass36_0.<coreDoGetPiping>b__0 () [0x00029] in <759bd83d98134a149cdf84e129a07d38>:0
at System.Threading.Tasks.Task.InnerInvoke () [0x0000f] in <3833a6edf2074b959d3dab898627f0ac>:0
at System.Threading.Tasks.Task.Execute () [0x00000] in <3833a6edf2074b959d3dab898627f0ac>:0
at Duplicati.Library.Main.BackendManager.coreDoGetPiping (Duplicati.Library.Main.BackendManager+FileEntryItem item, Duplicati.Library.Interface.IEncryption useDecrypter, System.Int64& retDownloadSize, System.String& retHashcode) [0x002d3] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.BackendManager.DoGet (Duplicati.Library.Main.BackendManager+FileEntryItem item) [0x002ff] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.BackendManager.ThreadRun () [0x000ff] in <759bd83d98134a149cdf84e129a07d38>:0
<...omitted...>
2019-11-19 04:20:17 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Get - Started: duplicati-bd743e3577a764e6eabba37e83ec36cac.dblock.zip.aes (249.59 MB)
2019-11-19 04:20:28 +00 - [Retry-Duplicati.Library.Main.BackendManager-RetryGet]: Operation Get with file duplicati-bd743e3577a764e6eabba37e83ec36cac.dblock.zip.aes attempt 1 of 5 failed with message: Thread was being aborted.
System.Threading.ThreadAbortException: Thread was being aborted.
at (wrapper managed-to-native) System.Threading.Monitor.Monitor_wait(object,int)
at System.Threading.Monitor.ObjWait (System.Boolean exitContext, System.Int32 millisecondsTimeout, System.Object obj) [0x0002f] in <3833a6edf2074b959d3dab898627f0ac>:0
at System.Threading.Monitor.Wait (System.Object obj, System.Int32 millisecondsTimeout, System.Boolean exitContext) [0x0000e] in <3833a6edf2074b959d3dab898627f0ac>:0
at System.Threading.Monitor.Wait (System.Object obj) [0x00000] in <3833a6edf2074b959d3dab898627f0ac>:0
at Renci.SshNet.Sftp.SftpFileReader.Read () [0x0004f] in <c60291af03764e69b153abec058a6ec5>:0
at Renci.SshNet.SftpClient.InternalDownloadFile (System.String path, System.IO.Stream output, Renci.SshNet.Sftp.SftpDownloadAsyncResult asyncResult, System.Action`1[T] downloadCallback) [0x00078] in <c60291af03764e69b153abec058a6ec5>:0
at Renci.SshNet.SftpClient.DownloadFile (System.String path, System.IO.Stream output, System.Action`1[T] downloadCallback) [0x00006] in <c60291af03764e69b153abec058a6ec5>:0
at Duplicati.Library.Backend.SSHv2.Get (System.String remotename, System.IO.Stream stream) [0x00012] in <40ac48623b834b889568d306e7f7925b>:0
at Duplicati.Library.Main.BackendManager.coreDoGetPiping (Duplicati.Library.Main.BackendManager+FileEntryItem item, Duplicati.Library.Interface.IEncryption useDecrypter, System.Int64& retDownloadSize, System.String& retHashcode) [0x00262] in <759bd83d98134a149cdf84e129a07d38>:0
2019-11-19 04:20:28 +00 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
at Duplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile.get_TempFile () [0x00008] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.Operation.CompactHandler.DoCompact (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Boolean hasVerifiedBackend, System.Data.IDbTransaction& transaction, Duplicati.Library.Main.BackendManager sharedBackend) [0x00264] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.Operation.DeleteHandler.DoRun (Duplicati.Library.Main.Database.LocalDeleteDatabase db, System.Data.IDbTransaction& transaction, System.Boolean hasVerifiedBacked, System.Boolean forceCompact, Duplicati.Library.Main.BackendManager sharedManager) [0x00397] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired (Duplicati.Library.Main.BackendManager backend, System.Int64 lastVolumeSize) [0x000a5] in <759bd83d98134a149cdf84e129a07d38>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00d9f] in <759bd83d98134a149cdf84e129a07d38>:0
