Error message about remote volumes marked as deleted
:heart: @kenkendk
If you are feeling brave, it should be possible to remove the row with the key repair-in-progress from the Configuration table:
DELETE FROM "Configuration" WHERE "Key" = 'repair-in-progress'
This removes the error, but the database is still validated.
@kenkendk thank you!
looks like with the SQL tweak it finally did the trick :raising_hands:
after that, I just triggerred a Repair which was quick, and triggerred a new Run to confirm things are working again.
thanks again for all your help! :heart:
