4 juil. 2023 22:25: L’opération Backup a échoué avec l’erreur : Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content
{“ClassName”:“System.Security.Cryptography.CryptographicException”,“Message”:“Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content”,“Data”:null,“InnerException”:{“ClassName”:“SharpAESCrypt.SharpAESCrypt+HashMismatchException”,“Message”:“Message has been altered, do not trust content”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:" à SharpAESCrypt.SharpAESCrypt.Read(Byte buffer, Int32 offset, Int32 count)\r\n à Duplicati.Library.Utility.Utility.CopyStream(Stream source, Stream target, Boolean tryRewindSource, Byte buf)\r\n à Duplicati.Library.Encryption.EncryptionBase.Decrypt(Stream input, Stream output)“,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:“8\nRead\nSharpAESCrypt, Version=1.3.3.0, Culture=neutral, PublicKeyToken=null\nSharpAESCrypt.SharpAESCrypt\nInt32 Read(Byte, Int32, Int32)”,“HResult”:-2146233296,“Source”:“SharpAESCrypt”,“WatsonBuckets”:null},“HelpURL”:null,“StackTraceString”:” à Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()\r\n à Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)\r\n à Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBackend, Boolean forceCompact, BackendManager sharedManager)\r\n à Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)\r\n à Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()\r\n— Fin de la trace de la pile à partir de l’emplacement précédent au niveau duquel l’exception a été levée —\r\n à System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n à CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)\r\n à Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)\r\n à Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action1 method)\r\n à Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter)\r\n à Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nget_TempFile\nDuplicati.Library.Main, Version=2.0.7.1, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile\nDuplicati.Library.Utility.TempFile get_TempFile()","HResult":-2146233296,"Source":"Duplicati.Library.Main","WatsonBuckets":null} 4 juil. 2023 22:25: Fatal error {"ClassName":"System.Security.Cryptography.CryptographicException","Message":"Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content","Data":null,"InnerException":{"ClassName":"SharpAESCrypt.SharpAESCrypt+HashMismatchException","Message":"Message has been altered, do not trust content","Data":null,"InnerException":null,"HelpURL":null,"StackTraceString":" à SharpAESCrypt.SharpAESCrypt.Read(Byte[] buffer, Int32 offset, Int32 count)\r\n à Duplicati.Library.Utility.Utility.CopyStream(Stream source, Stream target, Boolean tryRewindSource, Byte[] buf)\r\n à Duplicati.Library.Encryption.EncryptionBase.Decrypt(Stream input, Stream output)","RemoteStackTraceString":null,"RemoteStackIndex":0,"ExceptionMethod":"8\nRead\nSharpAESCrypt, Version=1.3.3.0, Culture=neutral, PublicKeyToken=null\nSharpAESCrypt.SharpAESCrypt\nInt32 Read(Byte[], Int32, Int32)","HResult":-2146233296,"Source":"SharpAESCrypt","WatsonBuckets":null},"HelpURL":null,"StackTraceString":" à Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()\r\n à Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)\r\n à Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBackend, Boolean forceCompact, BackendManager sharedManager)\r\n à Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)\r\n à Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__20.MoveNext()\r\n--- Fin de la trace de la pile à partir de l'emplacement précédent au niveau duquel l'exception a été levée ---\r\n à System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n à CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)\r\n à Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.<Backup>b__0(BackupResults result)\r\n à Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action1 method)\r\n à Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)\r\n à Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)“,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:“8\nget_TempFile\nDuplicati.Library.Main, Version=2.0.7.1, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile\nDuplicati.Library.Utility.TempFile get_TempFile()”,“HResult”:-2146233296,“Source”:“Duplicati.Library.Main”,“WatsonBuckets”:null}
4 juil. 2023 22:25: Backend event: Get - Completed: duplicati-bcb85e7dfad2e4206824db471ea13398c.dblock.zip.aes (100,05 MB)
4 juil. 2023 22:25: Backend event: Get - Started: duplicati-bcb85e7dfad2e4206824db471ea13398c.dblock.zip.aes (100,05 MB)
4 juil. 2023 22:25: Failed to retrieve file duplicati-b5fb72b02fd474b51a5ada216f3e72105.dblock.zip.aes
{“ClassName”:“System.Security.Cryptography.CryptographicException”,“Message”:“Échec du déchiffrement des données (phrase de passe invalide ?) : Message has been altered, do not trust content”,“Data”:null,“InnerException”:{“ClassName”:“SharpAESCrypt.SharpAESCrypt+HashMismatchException”,“Message”:“Message has been altered, do not trust content”,“Data”:null,“InnerException”:null,“HelpURL”:null,“StackTraceString”:” à SharpAESCrypt.SharpAESCrypt.Read(Byte buffer, Int32 offset, Int32 count)\r\n à Duplicati.Library.Utility.Utility.CopyStream(Stream source, Stream target, Boolean tryRewindSource, Byte buf)\r\n à Duplicati.Library.Encryption.EncryptionBase.Decrypt(Stream input, Stream output)“,“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:“8\nRead\nSharpAESCrypt, Version=1.3.3.0, Culture=neutral, PublicKeyToken=null\nSharpAESCrypt.SharpAESCrypt\nInt32 Read(Byte, Int32, Int32)”,“HResult”:-2146233296,“Source”:“SharpAESCrypt”,“WatsonBuckets”:null},“HelpURL”:null,“StackTraceString”:” à Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()\r\n à Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)\r\n à Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBackend, Boolean forceCompact, BackendManager sharedManager)\r\n à Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)\r\n à Duplicati.Library.Main.Operation.BackupHandler.d__20.MoveNext()\r\n— Fin de la trace de la pile à partir de l’emplacement précédent au niveau duquel l’exception a été levée —\r\n à System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()\r\n à CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)\r\n à Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)\r\n à Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action`1 method)\r\n à Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter)\r\n à Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)",“RemoteStackTraceString”:null,“RemoteStackIndex”:0,“ExceptionMethod”:“8\nget_TempFile\nDuplicati.Library.Main, Version=2.0.7.1, Culture=neutral, PublicKeyToken=null\nDuplicati.Library.Main.AsyncDownloader+AsyncDownloaderEnumerator+AsyncDownloadedFile\nDuplicati.Library.Utility.TempFile get_TempFile()”,“HResult”:-2146233296,“Source”:“Duplicati.Library.Main”,“WatsonBuckets”:null}
4 juil. 2023 22:25: Backend event: Get - Failed: duplicati-b5fb72b02fd474b51a5ada216f3e72105.dblock.zip.aes (100,00 MB)
4 juil. 2023 22:25: Backend event: Get - Started: duplicati-b5fb72b02fd474b51a5ada216f3e72105.dblock.zip.aes (100,00 MB)
4 juil. 2023 22:25: Backend event: Get - Retrying: duplicati-b5fb72b02fd474b51a5ada216f3e72105.dblock.zip.aes (100,00 MB)
