I don’t have a Mac, but I don’t think logs are relevant. Apple took Python away, which broke TrayIcon, however I think Duplicati itself is still running (aside from that…). The forum thread seeking fixes is at
There’s also a GitHub issue thread. If you happen to be good at Python, you can join in on the efforts.
This may need the Mac community to find a fix because the Duplicati project has no Mac person now.
I am more of a user to Dupicati, but still thanks for pointing me to the clues. Not sure if I can find the path where it asked for python, and I can edit it to look for python3 instead…
That by itself won’t suffice because the current script is for Python 2. Conversion might be possible,
however there is apparently now a new worry about how much Apple removed. See GitHub thread.
Remove python 2 dependencies #4690 was the thought needing Mac community before that worry.
If you have expertise in the area, please help over on GitHub work or previous technical forum topic.
