Hi.
Is the Duplicati scheduler only active when a user logged in and the GUI application is running (taskbar icon)?
I use Duplicati to run backups on a windows server, where not always a user session is active and thus the gui application is not running.
The best method for me would be to export the backup as command line and schedule the command in the windows task scheduler, I guess?
Maybe it should be mentioned somwhere that the GUI application has to be running for the scheduler to work. I assumed duplicati was running as a service to schedule the backups when I set it up…
Thanks for the quick reply. I am going to use the service install.
I assume the Duplicati.GUI.TrayIcon.exe should be removed from the startup to prevent conflicts when Duplicati is installed as a service?
You can still use the Traycon but you have to add a parameter:
“C:\Program Files\Duplicati 2\Duplicati.GUI.TrayIcon.exe” --no-hosted-server.
I’m using it while Duplicati is running as a server.
BTW: A good way of showing your appreciation for a post is to like it: just press the button under the post.
If you asked the original question, you can also mark an answer as the accepted answer which solved your problem using the tick-box button you see under each reply.
All of this also helps the forum software distinguish interesting from less interesting posts when compiling summary emails.
In your screenshot I see that the Duplicati server instance is listening on port 8300. The default port for Duplicati is 8200 (unless already in use), so it seems that there are multiple instances running.
Probably the Windows service and the Duplicati tray icon both run a Duplicati server instance, with the Duplicati tray icon listening on port 8300.What happens if you change 8300 to 8200 in the address bar in your web browser?
It works now. I uninstalled the service, then uninstalled Duplicati and used the .zip variant of Duplicati and installed the service in portable mode. Did a reboot in between and then could import my previously exported backups.
The re-installation and setup must have fixed the multiple instance issue if that was the problem.
