Duplicati grafana dashboard
Hi all,
Wanted to share this with everyone who is interested. I have been playing with nodered, influxdb and grafana to get to some nice dashboard. Might not be perfect - but I am more than happy with it.
Basically, nodered processes the resulting json files that can be posted by duplicati into an influxdb timeseries database, which is visualized by using a grafana dashboard.
Feel free to comment, suggest changes, …
Regards,
Wim
That’s really cool! Thanks for sharing!
Today looks great! I already have grafana for teslamate, I’ll have to add this!
from the installation instructions I am stuck on “Import the project in nodered”
how to import that mentioned project into nodered, I was able to run nodered in docker but have no idea how to import a project, where can I find some easy install instructions?
You have to enable projects in nodered.
https://nodered.org/docs/user-guide/projects/
I guess you need to fork the github to your own account and link nodered project to your fork.
But likely importing the flow.json as a flow will work as well.
Not an expert…
yes importing the flow is possible, so I didn’t try the project stuff
Thanks!
I added a mention on the GitHub remote management thread for those who might be interested.
