Hi folks,
I’m confused. I use the latest beta build of Duplicati but cannot see Tardigrade listed as a storage provider. What am I doing wrong?
Hi folks,
Welcome to the forum @query1234
If you saw a reference to “The newest version of Duplicati” on the Storj Labs blog, that means newer than latest Beta. Duplicati calls these “Canary” releases, and they’re the earliest public testing channel around.
Changes in this version:
Then it looks like 2.0.5.108 and 2.0.5.109 had some fixes – that’s the reason that Canary releases exist.
You’re welcome to help shake out issues in the software by running Canary, but sometimes bugs get in.
Settings in Duplicati will let you change your update channel, or an actual install will change the channel.
Storage Providers probably needs an update before Tardigrade hits Beta. Meanwhile, here’s its help text:
C:\ProgramData\Duplicati\duplicati-2.0.5.110_canary_2020-08-10>Duplicati.CommandLine.exe help tardigrade
Tardigrade Decentralized Cloud Storage (tardigrade):
This backend can read and write data to the Tardigrade Decentralized Cloud
Storage.
Supported options:
--tardigrade-auth-method (String): The authentication method
The authentication method describes which way to use to connect to the
network - either via API key or via an access grant.
* default value: API key
--tardigrade-satellite (String): The satellite
The satellite that keeps track of all metadata. Use a Tardigrade-grade
server for high-performance SLA-backed connectivity or use a community
server. Or even host your own.
* default value: us-central-1.tardigrade.io:7777
--tardigrade-api-key (String): The API key
The API key grants access to a specific project on your chosen satellite.
Head over to the dashboard of your satellite to create one if you do not
already have an API key.
--tardigrade-secret (Password): The encryption passphrase
The encryption passphrase is used to encrypt your data before sending it
to the tardigrade network. This passphrase can be the only secret to
provide - for Tardigrade you do not necessary need any additional
encryption (from Duplicati) in place.
--tardigrade-shared-access (String): The access grant
An access grant contains all information in one encrypted string. You may
use it instead of a satellite, API key and secret.
--tardigrade-bucket (String): The bucket
The bucket where the backup will reside in.
--tardigrade-folder (String): The folder
The folder within the bucket where the backup will reside in.
I ran into this also. I’m just trying to setup duplicati/tardigrade for the first time, using Docker with Version: - 2.0.5.110_canary_2020-08-10 and Tardigrade isn’t on the list of destinations. When I run that command above, I get:
(base):~ $ docker run --rm duplicati/duplicati:canary duplicati-cli help tardigrade
Topic not found: tardigrade
See duplicati.commandline.exe help <topic> for more information.
General: example, changelog
Commands: backup, find, restore, delete, compact, test, compare, purge,
vacuum
Repair: repair, affected, list-broken-files, purge-broken-files
Debug: debug, logging, create-report, test-filters, system-info, send-mail
Targets: aftp, azure, b2, box, cloudfiles, dropbox, ftp, file, googledrive,
gcs, hubic, jottacloud, mega, msgroup, onedrivev2, sharepoint, openstack,
rclone, s3, ssh, od4b, mssp, sia, tahoe, cos, webdav
Modules: aes, gpg, zip, 7z, console-password-input, mssql-options,
hyperv-options, http-options, sendhttp, sendmail, runscript, sendxmpp,
check-mono-ssl
Formats: date, time, size, encryption, compression
Advanced: mail, advanced, returncodes, filter, filter-groups, <option>
http://www.duplicati.com/ Version: - 2.0.5.110_canary_2020-08-10
Anyone else seeing this?
Welcome to the forum @stonematt
“help tardigrade” works here on Linux too, and it also shows up on the main help screen (unlike yours):
$ duplicati-cli help
Commands: backup, find, restore, delete, compact, test, compare, purge, vacuum
Targets: tahoe, aftp, hubic, cos, googledrive, gcs, tardigrade, rclone, jottacloud, mega, ftp, s3, openstack, b2, cloudfiles, webdav, dropbox, azure, od4b, mssp, box, file, ssh, msgroup, onedrivev2, sharepoint, sia
Modules: aes, gpg, zip, 7z, console-password-input, mssql-options, hyperv-options, http-options, sendhttp, sendmail, runscript, sendxmpp, check-mono-ssl
Which Docker are you using (duplicati, linuxserver, etc.)? I don’t use it, but maybe there’s an issue there.
If you look inside, Duplicati might be in /usr/lib/duplicati. Is there Duplicati.Library.Backend.Tardigrade.dll?
Maybe @TopperDEL knows what might cause tardigrade to be missing.
It might be because you are missing a mono-version, that is necessary for the Tardigrade-Backend (and some other) to work - but I’m not exactly sure.
This might be related here:
I wonder if it’s Beta or Canary? It’d be nice if a dev can confirm this on their system, but we still don’t know exactly what Docker @stonematt is running, or where it was obtained from. There are several suppliers.
I’m running 2.0.5.110 docker (official Duplicati image) and it shows Tardigrade as a destination option.
