Download links point all to github site
All download links on http://www.duplicati.com/download point to Releases · duplicati/duplicati · GitHub. Why has this changed? I used to get a direct download to a setup file for the specific platform.
A normal user wil not be able to download the beta release at this moment for his platform I think.
Best regards, Patrick
Hello @pahendriks and welcome to the forum!
Is it OK now? I didn’t do anything, but somebody (or some tool) might have fixed a web server recently.
Firefox view-source:https://updates.duplicati.com/beta/latest-installers.js was giving:
<html>
<head><title>502 Bad Gateway</title></head>
<body bgcolor="white">
<center><h1>502 Bad Gateway</h1></center>
<hr><center>nginx/1.11.5</center>
</body>
</html>
instead of its normal list of installers. updates.duplicati.com seems to do 502 Bad Gateway sometimes. There are other reports in the forum, usually on update failure, but maybe download links also degrade?
Yes it works again!!
Thanks!!
Hi there,
I’ve got the same problem… none of the download links are working and/or are pointing to github.
Can you have a look at it?
Same symptom as last time. This won’t help everyone, but link to beta is v2.0.4.5-2.0.4.5_beta_2018-11-28
502 Bad Gateway
nginx/1.11.5
