The last week I’ve been getting this error a lot and I’m wondering if there’s a way to fix it besides deleted the backup DB and restarting.
I’ve tried repairing and recreating the DB but that hasn’t helped.
When I run the backup manually it seems to work though, which is weird. It always seems to fail on a scheduled backup.
Any tips?
This is the stacktrace I’m seeing in the logs related to the error message:
System.IO.IOException: Gegevensfout (cyclische redundantiecontrole) bij Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile() bij Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend) bij Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBacked, Boolean forceCompact, BackendManager sharedManager) bij Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize) bij Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext() — Einde van stacktracering vanaf vorige locatie waar uitzondering is opgetreden — bij System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() bij CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task) bij Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result) bij Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action`1 method) bij Duplicati.Library.Main.Controller.Backup(String inputsources, IFilter filter) bij Duplicati.Server.Runner.Run(IRunnerData data, Boolean fromQueue)
Btw, when I get the error message and I press the Show button it takes me to the backup log, but this is empty because the backup fails. It took me a while to figure out there’s also a system log where you can see the actual error.
