Duplicati 2.0.4.5_beta_2018-11-28 running on Mac OS X 10.13.6 as a service via launchd script. Upgraded from prior beta version that had been running well for many months without issue.
Whenever I go to run a backup now, I get the mono ssl issue after a couple puts.
2018-12-16 21:36:59 -05 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b371fe5c97ecb43f7b43fef6cd022394f.dblock.zip.aes (19.91 MB),
Warnings: [
2018-12-16 21:32:31 -05 - [Warning-Duplicati.Library.Modules.Builtin.CheckMonoSSL-MissingCerts]: No certificates found, you can install some with one of these commands:
cert-sync /etc/ssl/certs/ca-certificates.crt #for Debian based systems
cert-sync /etc/pki/tls/certs/ca-bundle.crt #for RedHat derivatives
curl -O https://curl.haxx.se/ca/cacert.pem; cert-sync --user cacert.pem; rm cacert.pem #for MacOS
Read more: http://www.mono-project.com/docs/about-mono/releases/3.12.0/#cert-sync
Unfortunately, the instructions for the prior post somebody marked as solved, do not seem to work.
Hopefully when I re-install the old one it’ll go back to working again. :\
