For the past 2 days, I have not had a successful backup. When I logged into the browser UI on a lan-connected machine, I saw red error dialogs about /tmp filesystem being full.
I came to the host machine and logged into the UI and saw the following, which keeps repeating in a loop:
starting backup
verifying backend data
completing (previous backup)
counting files nnn/xxxxx
The connection to the server is lost. Attempting connection in xxx seconds
Connecting to server.
Hangs at this point.
Refreshing browser page shows “Not logged in”
Log in with password, and this restarts the whole cycle. Rebooting the computer has no effect.
No log is produced.
I am running
Duplicati - 2.0.6.3_beta_2021-06-17
Linux xxxxxxx 5.18.17-100.fc35.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Aug 11 14:34:40 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Kindly suggest solution
Do you use a separate device for /tmp? that’s the usual reason for this kind of problem, there is still plenty of free space but not where it’s needed for Duplicati.
No, I let Fedora assign tmpfs. By default, it assigns half of RAM size, so my tmpfs is 8 GB. I have increased it to 64 GB, but still get stuck in the same loop.
sudo mount -o remount,size=64G,noatime /tmp
Note that I rarely get the /tmp/ full errors. Mostly just the loop that I mention. During this, /tmp remains available.
df -h /tmp
Filesystem Size Used Avail Use% Mounted on
tmpfs 64G 34M 64G 1% /tmp
I found the following in journalctl:
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: mono-sgen: pthread_mutex_lock.c:90: ___pthread_mutex_lock: Assertion `mutex->__data.__owner == 0' failed.
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: =================================================================
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: Native Crash Reporting
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: Got a SIGABRT while executing native code. This usually indicates
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: a fatal error in the mono runtime or one of the native libraries
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: used by your application.
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: Native stacktrace:
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x55a61a07b83a - /usr/bin/mono-sgen :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x55a61a044c5e - /usr/bin/mono-sgen :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x55a61a0787dc - /usr/bin/mono-sgen :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f1974055350 - /lib64/libc.so.6 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19740a1afc - /lib64/libc.so.6 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19740552a6 - /lib64/libc.so.6 : raise
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19740287f3 - /lib64/libc.so.6 : abort
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f197402871b - /lib64/libc.so.6 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f197404e1f6 - /lib64/libc.so.6 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19740a32a0 - /lib64/libc.so.6 : pthread_mutex_lock
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19743d86da - /lib64/libnss_sss.so.2 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19743d91ee - /lib64/libnss_sss.so.2 :
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f19743db126 - /lib64/libnss_sss.so.2 : _nss_sss_getpwuid_r
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f197411795f - /lib64/libc.so.6 : getpwuid_r
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x7f196436b447 - /lib64/libMonoPosixHelper.so : Mono_Posix_Syscall_getpwuid_r
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: 0x414261d9 - Unknown
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: Telemetry Dumper:
Aug 16 01:21:44 XXXXX3 duplicati-server[1588]: Pkilling 0x139746404689472x from 0x139746402588224x
et al
ts678
August 16, 2022, 9:15pm
5
Make sure your Options screen Remote volume size is not something huge. The default is just 50 MB.
I see you posted to below, but didn’t give any guessing as to what changed 2 days ago. Can you help?
Suddenly started crashing - mono-sgen pthread_mutex_lock.c
I’m not sure what issue we’re chasing now. Maybe both? Maybe keep /tmp here and mono crash there?
Thanks for your assistance.
Remote Volume Size is 10 MB. As far as I recall, this was the default when I configured this backup.
I posted to other thread since it seemed it might be related.
I’m not convinced that /tmp is the real issue, since it only happens occasionally.
Since the last successful backup, I performed a routine dnf --refresh upgrade. Here is the history of what was changed and warnings issued.
[xxxxx3@XXXXX3 ~]$ dnf history info 631
Transaction ID : 631
Begin time : Sat 13 Aug 2022 03:32:20 PM EDT
Begin rpmdb : fxxx5
End time : Sat 13 Aug 2022 03:36:01 PM EDT (221 seconds)
End rpmdb : bxxxd
User : JimR <xxxxx3>
Return-Code : Success
Releasever : 35
Command Line : --refresh upgrade
Comment :
Packages Altered:
Install kernel-5.18.16-100.fc35.x86_64 @updates
Install kernel-core-5.18.16-100.fc35.x86_64 @updates
Install kernel-devel-5.18.16-100.fc35.x86_64 @updates
Install kernel-modules-5.18.16-100.fc35.x86_64 @updates
Install kernel-modules-extra-5.18.16-100.fc35.x86_64 @updates
Upgrade brave-browser-1.42.88-1.x86_64 @brave-browser-rpm-release.s3.brave.com_x86_64_
Upgraded brave-browser-1.41.100-1.x86_64 @@System
Upgrade annobin-docs-10.79-1.fc35.noarch @updates
Upgraded annobin-docs-10.66-2.fc35.noarch @@System
Upgrade annobin-plugin-gcc-10.79-1.fc35.x86_64 @updates
Upgraded annobin-plugin-gcc-10.66-2.fc35.x86_64 @@System
Upgrade bind-libs-32:9.16.31-1.fc35.x86_64 @updates
Upgraded bind-libs-32:9.16.30-1.fc35.x86_64 @@System
Upgrade bind-license-32:9.16.31-1.fc35.noarch @updates
Upgraded bind-license-32:9.16.30-1.fc35.noarch @@System
Upgrade bind-utils-32:9.16.31-1.fc35.x86_64 @updates
Upgraded bind-utils-32:9.16.30-1.fc35.x86_64 @@System
Upgrade bluez-5.65-1.fc35.x86_64 @updates
Upgraded bluez-5.64-1.fc35.x86_64 @@System
Upgrade bluez-libs-5.65-1.fc35.i686 @updates
Upgraded bluez-libs-5.64-1.fc35.i686 @@System
Upgrade bluez-libs-5.65-1.fc35.x86_64 @updates
Upgraded bluez-libs-5.64-1.fc35.x86_64 @@System
Upgrade ca-certificates-2022.2.54-1.0.fc35.noarch @updates
Upgraded ca-certificates-2021.2.52-1.0.fc35.noarch @@System
Upgrade dovecot-1:2.3.19.1-3.fc35.x86_64 @updates
Upgraded dovecot-1:2.3.19-1.fc35.x86_64 @@System
Upgrade egl-wayland-1.1.10-6.20220726gitaaf8608.fc35.i686 @updates
Upgraded egl-wayland-1.1.10-4.20220621git53b6a87.fc35.i686 @@System
Upgrade egl-wayland-1.1.10-6.20220726gitaaf8608.fc35.x86_64 @updates
Upgraded egl-wayland-1.1.10-4.20220621git53b6a87.fc35.x86_64 @@System
Upgrade fedora-release-35-37.noarch @updates
Upgraded fedora-release-35-36.noarch @@System
Upgrade fedora-release-common-35-37.noarch @updates
Upgraded fedora-release-common-35-36.noarch @@System
Upgrade fedora-release-identity-basic-35-37.noarch @updates
Upgraded fedora-release-identity-basic-35-36.noarch @@System
Upgrade firefox-103.0.1-2.fc35.x86_64 @updates
Upgraded firefox-102.0-1.fc35.x86_64 @@System
Upgrade gegl04-0.4.38-1.fc35.x86_64 @updates
Upgraded gegl04-0.4.36-1.fc35.x86_64 @@System
Upgrade ghostscript-9.56.1-1.fc35.x86_64 @updates
Upgraded ghostscript-9.55.0-2.fc35.x86_64 @@System
Upgrade ghostscript-tools-fonts-9.56.1-1.fc35.x86_64 @updates
Upgraded ghostscript-tools-fonts-9.55.0-2.fc35.x86_64 @@System
Upgrade ghostscript-tools-printing-9.56.1-1.fc35.x86_64 @updates
Upgraded ghostscript-tools-printing-9.55.0-2.fc35.x86_64 @@System
Upgrade giflib-5.2.1-9.fc35.x86_64 @updates
Upgraded giflib-5.2.1-8.fc35.x86_64 @@System
Upgrade java-1.8.0-openjdk-headless-1:1.8.0.342.b07-1.fc35.x86_64 @updates
Upgraded java-1.8.0-openjdk-headless-1:1.8.0.332.b09-1.fc35.x86_64 @@System
Upgrade java-11-openjdk-headless-1:11.0.16.0.8-1.fc35.x86_64 @updates
Upgraded java-11-openjdk-headless-1:11.0.15.0.10-1.fc35.x86_64 @@System
Upgrade java-latest-openjdk-1:18.0.2.0.9-1.rolling.fc35.x86_64 @updates
Upgraded java-latest-openjdk-1:18.0.1.1.2-1.rolling.fc35.x86_64 @@System
Upgrade java-latest-openjdk-headless-1:18.0.2.0.9-1.rolling.fc35.x86_64 @updates
Upgraded java-latest-openjdk-headless-1:18.0.1.1.2-1.rolling.fc35.x86_64 @@System
Upgrade koji-1.29.1-3.fc35.noarch @updates
Upgraded koji-1.29.1-1.fc35.noarch @@System
Upgrade libgs-9.56.1-1.fc35.x86_64 @updates
Upgraded libgs-9.55.0-2.fc35.x86_64 @@System
Upgrade libipa_hbac-2.7.3-1.fc35.x86_64 @updates
Upgraded libipa_hbac-2.7.1-2.fc35.x86_64 @@System
Upgrade librados2-2:16.2.10-1.fc35.x86_64 @updates
Upgraded librados2-2:16.2.9-3.fc35.x86_64 @@System
Upgrade librbd1-2:16.2.10-1.fc35.x86_64 @updates
Upgraded librbd1-2:16.2.9-3.fc35.x86_64 @@System
Upgrade libsss_autofs-2.7.3-1.fc35.x86_64 @updates
Upgraded libsss_autofs-2.7.1-2.fc35.x86_64 @@System
Upgrade libsss_certmap-2.7.3-1.fc35.x86_64 @updates
Upgraded libsss_certmap-2.7.1-2.fc35.x86_64 @@System
Upgrade libsss_idmap-2.7.3-1.fc35.x86_64 @updates
Upgraded libsss_idmap-2.7.1-2.fc35.x86_64 @@System
Upgrade libsss_nss_idmap-2.7.3-1.fc35.x86_64 @updates
Upgraded libsss_nss_idmap-2.7.1-2.fc35.x86_64 @@System
Upgrade libsss_sudo-2.7.3-1.fc35.x86_64 @updates
Upgraded libsss_sudo-2.7.1-2.fc35.x86_64 @@System
Upgrade libupnp-1.14.13-1.fc35.x86_64 @updates
Upgraded libupnp-1.14.12-1.fc35.x86_64 @@System
Upgrade libwebp-1.2.3-1.fc35.i686 @updates
Upgraded libwebp-1.2.2-1.fc35.i686 @@System
Upgrade libwebp-1.2.3-1.fc35.x86_64 @updates
Upgraded libwebp-1.2.2-1.fc35.x86_64 @@System
Upgrade lua-5.4.4-3.fc35.x86_64 @updates
Upgraded lua-5.4.4-1.fc35.x86_64 @@System
Upgrade lua-libs-5.4.4-3.fc35.x86_64 @updates
Upgraded lua-libs-5.4.4-1.fc35.x86_64 @@System
Upgrade nspr-4.34.0-2.fc35.i686 @updates
Upgraded nspr-4.34.0-1.fc35.i686 @@System
Upgrade nspr-4.34.0-2.fc35.x86_64 @updates
Upgraded nspr-4.34.0-1.fc35.x86_64 @@System
Upgrade nss-3.81.0-1.fc35.i686 @updates
Upgraded nss-3.79.0-1.fc35.i686 @@System
Upgrade nss-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-3.79.0-1.fc35.x86_64 @@System
Upgrade nss-softokn-3.81.0-1.fc35.i686 @updates
Upgraded nss-softokn-3.79.0-1.fc35.i686 @@System
Upgrade nss-softokn-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-softokn-3.79.0-1.fc35.x86_64 @@System
Upgrade nss-softokn-freebl-3.81.0-1.fc35.i686 @updates
Upgraded nss-softokn-freebl-3.79.0-1.fc35.i686 @@System
Upgrade nss-softokn-freebl-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-softokn-freebl-3.79.0-1.fc35.x86_64 @@System
Upgrade nss-sysinit-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-sysinit-3.79.0-1.fc35.x86_64 @@System
Upgrade nss-tools-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-tools-3.79.0-1.fc35.x86_64 @@System
Upgrade nss-util-3.81.0-1.fc35.i686 @updates
Upgraded nss-util-3.79.0-1.fc35.i686 @@System
Upgrade nss-util-3.81.0-1.fc35.x86_64 @updates
Upgraded nss-util-3.79.0-1.fc35.x86_64 @@System
Upgrade osinfo-db-20220727-1.fc35.noarch @updates
Upgraded osinfo-db-20220516-1.fc35.noarch @@System
Upgrade python-rpm-macros-3.10-12.fc35.noarch @updates
Upgraded python-rpm-macros-3.10-11.fc35.noarch @@System
Upgrade python-srpm-macros-3.10-12.fc35.noarch @updates
Upgraded python-srpm-macros-3.10-11.fc35.noarch @@System
Upgrade python3-bind-32:9.16.31-1.fc35.noarch @updates
Upgraded python3-bind-32:9.16.30-1.fc35.noarch @@System
Upgrade python3-koji-1.29.1-3.fc35.noarch @updates
Upgraded python3-koji-1.29.1-1.fc35.noarch @@System
Upgrade python3-rpm-4.17.1-3.fc35.x86_64 @updates
Upgraded python3-rpm-4.17.1-2.fc35.x86_64 @@System
Upgrade python3-rpm-macros-3.10-12.fc35.noarch @updates
Upgraded python3-rpm-macros-3.10-11.fc35.noarch @@System
Upgrade python3-sssdconfig-2.7.3-1.fc35.noarch @updates
Upgraded python3-sssdconfig-2.7.1-2.fc35.noarch @@System
Upgrade rpm-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-build-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-build-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-build-libs-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-build-libs-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-devel-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-devel-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-libs-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-libs-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-plugin-selinux-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-plugin-selinux-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-plugin-systemd-inhibit-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-plugin-systemd-inhibit-4.17.1-2.fc35.x86_64 @@System
Upgrade rpm-sign-libs-4.17.1-3.fc35.x86_64 @updates
Upgraded rpm-sign-libs-4.17.1-2.fc35.x86_64 @@System
Upgrade rsyslog-8.2204.0-2.fc35.x86_64 @updates
Upgraded rsyslog-8.2204.0-1.fc35.x86_64 @@System
Upgrade rust-srpm-macros-22-1.fc35.noarch @updates
Upgraded rust-srpm-macros-21-1.fc35.noarch @@System
Upgrade setup-2.14.1-1.fc35.noarch @updates
Upgraded setup-2.13.10-1.fc35.noarch @@System
Upgrade sssd-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-ad-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-ad-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-client-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-client-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-common-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-common-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-common-pac-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-common-pac-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-idp-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-idp-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-ipa-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-ipa-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-krb5-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-krb5-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-krb5-common-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-krb5-common-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-ldap-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-ldap-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-nfs-idmap-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-nfs-idmap-2.7.1-2.fc35.x86_64 @@System
Upgrade sssd-proxy-2.7.3-1.fc35.x86_64 @updates
Upgraded sssd-proxy-2.7.1-2.fc35.x86_64 @@System
Upgrade usbredir-0.12.0-2.fc35.x86_64 @updates
Upgraded usbredir-0.12.0-1.fc35.x86_64 @@System
Upgrade vim-common-2:9.0.137-1.fc35.x86_64 @updates
Upgraded vim-common-2:9.0.077-1.fc35.x86_64 @@System
Upgrade vim-data-2:9.0.137-1.fc35.noarch @updates
Upgraded vim-data-2:9.0.077-1.fc35.noarch @@System
Upgrade vim-enhanced-2:9.0.137-1.fc35.x86_64 @updates
Upgraded vim-enhanced-2:9.0.077-1.fc35.x86_64 @@System
Upgrade vim-filesystem-2:9.0.137-1.fc35.noarch @updates
Upgraded vim-filesystem-2:9.0.077-1.fc35.noarch @@System
Upgrade vim-minimal-2:9.0.137-1.fc35.x86_64 @updates
Upgraded vim-minimal-2:9.0.077-1.fc35.x86_64 @@System
Upgrade virtualbox-guest-additions-6.1.36-1.fc35.x86_64 @updates
Upgraded virtualbox-guest-additions-6.1.34-1.fc35.x86_64 @@System
Upgrade xen-libs-4.15.3-4.fc35.x86_64 @updates
Upgraded xen-libs-4.15.3-2.fc35.x86_64 @@System
Upgrade xen-licenses-4.15.3-4.fc35.x86_64 @updates
Upgraded xen-licenses-4.15.3-2.fc35.x86_64 @@System
Upgrade google-chrome-stable-104.0.5112.79-1.x86_64 @google-chrome
Upgraded google-chrome-stable-103.0.5060.134-1.x86_64 @@System
Upgrade akmod-nvidia-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded akmod-nvidia-3:515.57-1.fc35.x86_64 @@System
Upgrade nvidia-settings-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded nvidia-settings-3:515.57-1.fc35.x86_64 @@System
Upgrade nvidia-xconfig-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded nvidia-xconfig-3:515.57-1.fc35.x86_64 @@System
Upgrade xorg-x11-drv-nvidia-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-3:515.57-1.fc35.x86_64 @@System
Upgrade xorg-x11-drv-nvidia-cuda-libs-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-cuda-libs-3:515.57-1.fc35.x86_64 @@System
Upgrade xorg-x11-drv-nvidia-kmodsrc-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-kmodsrc-3:515.57-1.fc35.x86_64 @@System
Upgrade xorg-x11-drv-nvidia-libs-3:515.65.01-1.fc35.i686 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-libs-3:515.57-1.fc35.i686 @@System
Upgrade xorg-x11-drv-nvidia-libs-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-libs-3:515.57-1.fc35.x86_64 @@System
Upgrade xorg-x11-drv-nvidia-power-3:515.65.01-1.fc35.x86_64 @rpmfusion-nonfree-updates
Upgraded xorg-x11-drv-nvidia-power-3:515.57-1.fc35.x86_64 @@System
Reason Change AtomicParsley-0.9.5-18.fc35.x86_64 @fedora
Removed kernel-5.18.4-101.fc35.x86_64 @@System
Removed kernel-core-5.18.4-101.fc35.x86_64 @@System
Removed kernel-devel-5.18.4-101.fc35.x86_64 @@System
Removed kernel-modules-5.18.4-101.fc35.x86_64 @@System
Removed kernel-modules-extra-5.18.4-101.fc35.x86_64 @@System
Removed kmod-nvidia-5.18.4-101.fc35.x86_64-3:515.57-1.fc35.x86_64 @@System
Scriptlet output:
1 warning: /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/java.security created as /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/java.security.rpmnew
2 warning: /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/nss.fips.cfg created as /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/nss.fips.cfg.rpmnew
3 restored /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/java.security.rpmnew to /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/java.security
4 restored /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/nss.fips.cfg.rpmnew to /etc/java/java-1.8.0-openjdk/java-1.8.0-openjdk-1.8.0.342.b07-1.fc35.x86_64/lib/security/nss.fips.cfg
5 warning: /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/java.security created as /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/java.security.rpmnew
6 warning: /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/nss.fips.cfg created as /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/nss.fips.cfg.rpmnew
7 warning: /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/lib/security/public_suffix_list.dat created as /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/lib/security/public_suffix_list.dat.rpmnew
8 restored /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/java.security.rpmnew to /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/java.security
9 restored /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/nss.fips.cfg.rpmnew to /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/conf/security/nss.fips.cfg
10 restored /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/lib/security/public_suffix_list.dat.rpmnew to /etc/java/java-11-openjdk/java-11-openjdk-11.0.16.0.8-1.fc35.x86_64/lib/security/public_suffix_list.dat
11 warning: /etc/shadow created as /etc/shadow.rpmnew
jimkd1yv:
getpwuid_r
argh, this function again. And there is this thread about a sudden crash for a Fedora system with the same function involved:
I’ve been running duplicati-2.0.6.3-2.0.6.3_beta_20210617.noarch on Fedora 35 for at least a month now. It’s been backup up on schedule to a host on my LAN using SFTP. Then about a week ago, the jobs stopped completing. Duplicati itself would crash a little way into the job running. I don’t know what’s useful, so I’ll paste entries from /var/log/messages.
Any help in fixing this will be greatly appreciated.
Aug 9 20:35:42 fedora systemd[1]: Started duplicati.service - Duplicati web-server…
Maybe the same upgrade in both cases ? It’s Fedora 35 in both cases it seems.
