I could use a little help with a backup I’ve been running on some hyper-v vms. The backup destination is a windows network share. I’ve tried running a repair, and deleting and recreating the database, but nothing I’ve tried has resolved the problem.
The errors in the log include Failed while executing “Repair” with id: 2
System.IO.InvalidDataException: Found inconsistency in the following files while validating database:
C:\Users\Public\Documents\Hyper-V\Virtual Hard Disks\vm1.vhdx, actual size 20640169984, dbsize 20316160000, blocksetid: 38
. Run repair to fix it.
at Duplicati.Library.Main.Database.LocalDatabase.VerifyConsistency(IDbTransaction transaction, Int64 blocksize, Int64 hashsize, Boolean verifyfilelists)
at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.DoRun(LocalDatabase dbparent, Boolean updating, IFilter filter, NumberedFilterFilelistDelegate filelistfilter, BlockVolumePostProcessor blockprocessor)
at Duplicati.Library.Main.Operation.RecreateDatabaseHandler.Run(String path, IFilter filter, NumberedFilterFilelistDelegate filelistfilter, BlockVolumePostProcessor blockprocessor)
at Duplicati.Library.Main.Operation.RepairHandler.RunRepairLocal(IFilter filter)
at Duplicati.Library.Main.Operation.RepairHandler.Run(IFilter filter)
at Duplicati.Library.Main.Controller.Repair(IFilter filter)
Failed while executing “Backup with id” 2
Duplicati.Library.Interface.UserInformationException: Found 371 remote files that are not recorded in local storage, please run repair
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Controller.<>c__DisplayClass16_0.<Backup>b__0(BackupResults result)
Do you have any advice on how to fix this, or do I need to delete the remote files and start over?
