Hello,
Im getting a warning in my backup job at the end.
Warnings:
2018-11-19 12:54:31 +02 - [Warning-Duplicati.Library.Main.Operation.BackupHandler-SnapshotFailed]: Failed to create a snapshot: System.IO.FileNotFoundException: Could not load file or assembly 'AlphaVSS .x64.dll 'or one of its dependencies. The specified module could not be found.
File name: 'AlphaVSS.x64.dll'
In System.Reflection.RuntimeAssembly.nLoadFile (String path, Evidence evidence)
In System.Reflection.Assembly.LoadFile (String path)
In Duplicati.Library.Common.IO.VssBackupComponentsHelper.CreateVssBackupComponents ()
In Duplicati.Library.Common.IO.VssBackupComponentsHelper.GetVssBackupComponents ()
In Duplicati.Library.Snapshots.WindowsSnapshot.ctor (IEnumerable`1 sources, IDictionary`2 options)
In Duplicati.Library.Snapshots.SnapshotUtility.CreateWindowsSnapshot (IEnumerable`1 folders, Dictionary`2 options)
In Duplicati.Library.Main.Operation.BackupHandler.GetSnapshot (String [] sources, Options options)
Its a clean install and the files are present in the “Alphevss” folder, and i preformed an installation of Visual c++ 2017 and 2015 and still no luck.
Thanks, sorry for my ignorance but i am not that familiar on how to diagnose the dll file, is there any link to guidelines that can assist me to understand on how to recognize the missing dependencies?
UPDATE : i installed the “DependencyWalker” for a more friendly understanding of the problem and i noticed that i have ton of error with files like “API-MS-WIN-CORE-REGISTRY-L2-1-0.DLL”
My best guess is that the errors from DependencyWalker are just related to a new loading mechanism that it does not understand, aka false positives.
Unfortunately, that means that we are no closer to figuring out why it fails to load. Can you check the Windows EventLog and see if there are hints there?
