I am not sure if this happened only after the update to 2.0.2.1 or after some other point of time, but Duplicati is not launching anymore on my MacOS Sierra Machine.
Tried to install experimental builds, but there I also get the same issue. When I tried to install the experimental builds via the .pkg installation, the installation itself is even failing.
After trying to launch via Terminal I get the following result:
Crash!
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Exception: A serious error occurred in Duplicati: System.Exception: Failed to create, open or upgrade the database.
Error message: The database disk image is malformed
at Duplicati.Server.Program.GetDatabaseConnection (System.Collections.Generic.Dictionary2[TKey,TValue] commandlineOptions) [0x0023b] in <a6c0c2089b9a44ec9be5057a44f12116>:0 at Duplicati.Server.Program.RealMain (System.String[] args) [0x00206] in <a6c0c2089b9a44ec9be5057a44f12116>:0 ---> System.Exception: Failed to create, open or upgrade the database. Error message: The database disk image is malformed database disk image is malformed at Duplicati.Server.Program.GetDatabaseConnection (System.Collections.Generic.Dictionary
2[TKey,TValue] commandlineOptions) [0x0023b] in :0
at Duplicati.Server.Program.RealMain (System.String args) [0x00206] in :0
at Duplicati.Server.Program.RealMain (System.String args) [0x0065d] in :0
at (wrapper managed-to-native) System.Reflection.MonoMethod:InternalInvoke (System.Reflection.MonoMethod,object,object,System.Exception&)
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object parameters, System.Globalization.CultureInfo culture) [0x00032] in <4fdc5ed61a074cafb49fa42deb20d521>:0
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object parameters, System.Globalization.CultureInfo culture) [0x00048] in <4fdc5ed61a074cafb49fa42deb20d521>:0
at System.Reflection.MethodBase.Invoke (System.Object obj, System.Object parameters) [0x00000] in <4fdc5ed61a074cafb49fa42deb20d521>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String args) [0x00000] in <2e3a1be277654a188f84e503094300c3>:0
Crash!
at Duplicati.GUI.TrayIcon.HostedInstanceKeeper…ctor (System.String args) [0x00093] in :0
at Duplicati.GUI.TrayIcon.Program.RealMain (System.String _args) [0x00288] in :0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String args) [0x00000] in <2e3a1be277654a188f84e503094300c3>:0Unhandled Exception:
— End of inner exception stack trace —Server stack trace:
at Duplicati.Library.AutoUpdater.UpdaterManager.RunMethod (System.Reflection.MethodInfo method, System.String args) [0x0009c] in <2e3a1be277654a188f84e503094300c3>:0
at Duplicati.Library.AutoUpdater.UpdaterManager+<>c__DisplayClass53_0.b__0 () [0x00000] in <2e3a1be277654a188f84e503094300c3>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.WrapWithUpdater (Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy, System.Action wrappedFunction) [0x00157] in <2e3a1be277654a188f84e503094300c3>:0
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecent (System.Reflection.MethodInfo method, System.String cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x00050] in <2e3a1be277654a188f84e503094300c3>:0
at Duplicati.GUI.TrayIcon.Program.Main (System.String args) [0x0001c] in :0
at (wrapper managed-to-native) System.AppDomain:ExecuteAssembly (System.AppDomain,System.Reflection.Assembly,string)
at System.AppDomain.ExecuteAssemblyInternal (System.Reflection.Assembly a, System.String args) [0x00029] in <4fdc5ed61a074cafb49fa42deb20d521>:0
at System.AppDomain.ExecuteAssemblyByName (System.String assemblyName, System.String args) [0x00008] in <4fdc5ed61a074cafb49fa42deb20d521>:0
at (wrapper remoting-invoke-with-check) System.AppDomain:ExecuteAssemblyByName (string,string)
at (wrapper xdomain-dispatch) System.AppDomain:ExecuteAssemblyByName (object,byte&,byte&,string,string)Exception rethrown at [0]:
at (wrapper xdomain-invoke) System.AppDomain:ExecuteAssemblyByName (string,string)
at Duplicati.Library.AutoUpdater.UpdaterManager.RunFromMostRecent (System.Reflection.MethodInfo method, System.String cmdargs, Duplicati.Library.AutoUpdater.AutoUpdateStrategy defaultstrategy) [0x001fb] in <2e3a1be277654a188f84e503094300c3>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: A serious error occurred in Duplicati: System.Exception: Failed to create, open or upgrade the database.
