Can you say anything about where it is when it’s slow? Building partial temporary database ...
sometimes can get very slow (and has lots of forum posting) for large backups, but after that’s done it’s actually restoring files that proceeds. Have you restored any bits of files, or are you still doing database?
Choosing sizes in Duplicati discusses –dblock-size remote volume size, and deduplication –blocksize which at 100KB can make for huge database tables for large backups, and possible slow performance.
I’d think you could probably raise both values. --dblock-size can change anytime but applies only to new dblocks (workaround is compact). --blocksize might matter more for big backups but can’t be changed.
I can’t say how much this would speed up the restore phase, but recreate and backups are believed to scale up poorly when the administrative overhead gets high (might matter more than network latencies).
Restoring files if your Duplicati installation is lost possibly describes what you’re testing. Is that correct? Restoring this way makes a partial temporary database that’s (I think) designed for the specific restore, meaning it gets created faster than the database you would recreate if you wanted to continue backups.
Creating a long-term (at least long enough for a series of restores) database might be what you’re after. The REPAIR command can do this, and using –version (most recent is 0) can tame it a bit so it doesn’t spend its time doing all versions (which will take longer) if that’s good (one version, with full set of files).
Don’t try having two backups (with two databases) sharing one remote. That can lead to huge messes. Perhaps the temptation is another reason why a partial temporary database is the less dangerous path.
Can’t say offhand, and probably varies case-by-case (some report slowness without much CPU usage). There’s a large amount of work involved, including possibly decryption, unzipping. dealing with lots of DB queries (you can enjoy seeing those if you do About --> Show log --> Live --> Profiling), and such things.
How the restore process works and Features (which have performance prices) might give further ideas.
That’s a great attitude. There are definitely rough edges, complexities, and things one should learn about. One subtle point I found out after doing my own restore tests to the same system is that –no-local-blocks must be used to ensure remote data is actually used, as opposed to getting whatever it can from source. Your test is more purely reflective of disaster recovery. Always a wise thing to test before disaster occurs.
