As my original thread go hijacked and my question was never responded to, can someone give me the download link for the RPM of v2.0.5.108-2.0.5.108_canary_2020-07-09? I cannot find it on Github.
Thanks
Thanks
No RPM built for v2.0.5.108-2.0.5.108_canary_2020-07-09 #4253 says there isn’t one, but it’s your issue.
2.0.5.108_canary_2020-07-09 release area still has none. This mention will at least update GitHub issue.
Build expert might not have had time to look, but last I knew there was some understanding of the cause.
If you need 2.0.5.108 (and can’t do with 2.0.5.107), the autoupdater might get you there. It’s not an RPM (therefore has no RPM tools to break). You could probably just unzip the .zip file from the release area…
