how is it possible to reset my password on a linux system?
Best Rene
Best Rene
There’s the option of starting the server with
duplicati-server --webservice-password=secure-password
Kenneth talks a little about it here
must the server beeing stopped before? If yes how can i stop the service?
On Linux it’s likely running as a systemd service so you would need to stop it. I think it’s called “duplicati-server”
sudo systemctl stop duplicati-server
Then you can manually start it using the duplicati-server command and then stop that server after a few moments using Ctrl+C
Then start it again using systemd
sudo systemctl start duplicati-server
