I’ve tried creating a backup script on multiple Linux machines (running Ubuntu server/desktop) now to upload to my WebDAV server and I keep getting the same issue where I get to “Listing remote folder…” then everything just crashes.
Using the local system as the backup location works just fine, so the program is functioning, just the WebDAV protocol doesn’t work.
I’ve also deployed the script on multiple Windows machines just fine.
Script is basically:
duplicati-cli backup webdav://user:password@backup.server:8081/Folder/backup “/” --no-encryption
The actual script is a bit longer, as I’ve specified other flags, but modifying flags and the backup source doesn’t fix anything. I can literally put webdav://1 as the remote path and it still hangs when attempting to list the remote folder. I put the output below.
Backup started at 9/24/2021 10:02:48 PM
Checking remote backup …
Listing remote folder …
Fatal error => The request requires buffering data to succeed.System.Net.WebException: The request requires buffering data to succeed.
at System.Net.HttpWebRequest.GetResponseFromData (System.Net.WebResponseStream stream, System.Threading.CancellationToken cancellationToken) [0x0017e] in :0
at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.T ask1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Fun c
1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x00118] in :0
at Duplicati.Library.Main.BackendManager.List () [0x00049] in :0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Dupl icati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options option s, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Mai n.IBackendWriter log, System.Collections.Generic.IEnumerable1[T] protectedFiles ) [0x0000d] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplic ati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main. IBackendWriter log, System.Collections.Generic.IEnumerable
1[T] protectedFiles) [0x00000] in :0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.L ibrary.Main.BackendManager backend, System.String protectedfile) [0x0011d] in <e 60bc008dd1b454d861cfacbdd3760b9>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String so urces, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationTo ken token) [0x01048] in :0
at CoCoL.ChannelExtensions.WaitForTaskOrThrow (System.Threading.Tasks.Task tas k) [0x00050] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String sources , Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken t oken) [0x00009] in :0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.b__0 (Dupli cati.Library.Main.BackupResults result) [0x0004b] in <e60bc008dd1b454d861cfacbdd 3760b9>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String& paths, Duplicati.Library.Utility.IFilter& filter, System.Action1[T] method) [0x 0026f] in <e60bc008dd1b454d861cfacbdd3760b9>:0 at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Dup licati.Library.Utility.IFilter filter) [0x00074] in <e60bc008dd1b454d861cfacbdd3 760b9>:0 at Duplicati.CommandLine.Commands.Backup (System.IO.TextWriter outwriter, Syst em.Action
1[T] setup, System.Collections.Generic.List1[T] args, System.Collecti ons.Generic.Dictionary
2[TKey,TValue] options, Duplicati.Library.Utility.IFilter filter) [0x00119] in :0
at (wrapper delegate-invoke) System.Func6[System.IO.TextWriter,System.Action
1[Duplicati.Library.Main.Controller],System.Collections.Generic.List1[System.St ring],System.Collections.Generic.Dictionary
2[System.String,System.String],Dupli cati.Library.Utility.IFilter,System.Int32].invoke_TResult_T1_T2_T3_T4_T5(System. IO.TextWriter,System.Action1<Duplicati.Library.Main.Controller>,System.Collecti ons.Generic.List
1,System.Collections.Generic.Dictionary2<string, strin g>,Duplicati.Library.Utility.IFilter) at Duplicati.CommandLine.Program.ParseCommandLine (System.IO.TextWriter outwri ter, System.Action
1[T] setup, System.Boolean& verboseErrors, System.String ar gs) [0x00342] in :0
at Duplicati.CommandLine.Program.RunCommandLine (System.IO.TextWriter outwrite r, System.IO.TextWriter errwriter, System.Action`1[T] setup, System.String arg s) [0x00002] in :0
