After abackup is executed I always get warnings.
When I press the button “show” nothing happends or i get the massage “Failed to connect: database is locked database is locked”.
Can you help me with that?
Regards,
Dan
Hello
To get the most information about failures, try to export the backup as command line, then open a terminal (if you run Duplicati as a service, ensure that you have the appropriate privilege such as running as Administrator), and paste the command and start it (wait that no backup is running in the Web UI of course).
Thank you very much.
It was very helpful and it resolved the problem.
Regards,
Dan
