Looks like the web UI is failing to load. This can sometimes happen due to a caching issue. Try holding the Ctrl key and pressing the refresh/reload button.
Thank you for your response, but refresh isnt helping either.Anything else i should be looking into?
Can you try Chrome just as a test?
worked like a charm!
