Hey there is it normal to get warnings even if the files should be excluded? Or did I do anything wrong?
here are the warnings:
And here are my exclusions:
Hello
yes this seems unexpected. Could you:
-/source/docker/rr_server/lidarr/config/logs.db
thanks for the answer and sorry for the late reply.
here is a screenshot as text:
what is the live trace mode?
About / show log / Live
Once you have set the level to ‘verbose’ (you can open another tab to look at the trace while you start the backup in the first tab), look at the live trace and as soon as one of the error messages appears, disable the log by setting it to ‘disabled’ to avoid that it scrolls off screen. Then click on the ‘Failed to process path’ error message to reveal the trace.
