I try to backup a UnRaid server share by Duplicati run in a Docker container.
Backup in a cloud via WebDav is ok.
Backup in another UnRaid share is ok.
Backup to a local Netgear ReadyNAS has warnings a sometimes errors (see below).
Backup via Duplicati on Windows PC to the Netgear ReadyNAS is also ok.
What is the problem?
Warnings 3
- 2020-11-14 17:02:43 +01 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-bb598c5f168294b51a6f0dddfc5b384b4.dblock.zip is listed as Uploaded with size 50331648 but should be 52406507, please verify the sha256 hash “oHvNeUkBFOrwFV9d9AUJGs0ABp6uzfC/rabh9xzQZ6g=”
- 2020-11-14 17:02:43 +01 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-b80272ab95362409ca5542385284b9395.dblock.zip is listed as Uploaded with size 29360128 but should be 52343112, please verify the sha256 hash “adNmuLxMRXS0iRU7vpEys/5MaqJNDA9e4310AaYZ7vw=”
- 2020-11-14 17:02:43 +01 - [Warning-Duplicati.Library.Main.Operation.FilelistProcessor-MissingRemoteHash]: remote file duplicati-b9855977b6ff44fbeab41955a20432fdf.dblock.zip is listed as Uploaded with size 16777216 but should be 52331094, please verify the sha256 hash “dnVZIJSLw7u0cpA+zF/Zf2oXqyiayjZUXkyRqlauHbQ=”
Errors 1
- 2020-11-14 17:03:25 +01 - [Error-Duplicati.Library.Main.Operation.TestHandler-FailedToProcessFile]: Failed to process file duplicati-b80272ab95362409ca5542385284b9395.dblock.zip
System Info:
Duplicati: Duplicati.Server, Version=2.0.5.1, Culture=neutral, PublicKeyToken=null (Duplicati.Library.Main, Version=2.0.5.1, Culture=neutral, PublicKeyToken=null)
Autoupdate urls: https://updates.duplicati.com/beta/latest.manifest;https://alt.updates.duplicati.com/beta/latest.manifest
Update folder: /config/.config/Duplicati/updates
Base install folder: /app/duplicati
Version name: “2.0.5.1_beta_2020-01-18” (2.0.5.1)
Current Version folder /app/duplicati
OS: Unix 5.8.13.0
Uname: Linux 56863b57a8f2 5.8.13-Unraid #1 SMP Thu Oct 1 16:59:27 PDT 2020 x86_64 x86_64 x86_64 GNU/Linux
64bit: True (True)
Machinename: 56863b57a8f2
Processors: 4
.Net Version: 4.0.30319.42000
Mono: True (5.20.1.34) (5.20.1.34 (tarball Tue Jul 16 22:52:32 UTC 2019))
Locale: en-US, en-US, en-US
Date/time strings: dddd, MMMM d, yyyy - h:mm:ss tt
Tempdir: /tmp/
SQLite: 3.22.0 - Mono.Data.Sqlite.SqliteConnection
SQLite assembly: /usr/lib/mono/gac/Mono.Data.Sqlite/4.0.0.0__0738eb9f132ed756/Mono.Data.Sqlite.dll
Thanks for help
