I’ve created and run my first backup with Duplicati on a Synology NAS (with the official Duplicati Docker image). It deals with a little bit more than 0.5 TB towards my OneDrive for Business account. It takes a while (600-700 KB/s), but at the end everything seems okay, till the last phase… It seems stuck with the message “Waiting for upload to finish …” for about 18 hours now.
The live log with level Profiling says (no entry for the last 18 hours…):
- 22 feb. 2022 15:26: CommitUpdateRemoteVolume took 0:00:00:00.000
- 22 feb. 2022 15:26: Starting - CommitUpdateRemoteVolume
- 22 feb. 2022 15:26: Uploading a new fileset took 0:00:02:06.806
- 22 feb. 2022 15:26: CommitUpdateRemoteVolume took 0:00:00:00.203
- 22 feb. 2022 15:25: CommitAfterUpload took 0:00:00:00.079
- 22 feb. 2022 15:25: Starting - CommitAfterUpload
- 22 feb. 2022 15:25: Backend event: Put - Completed: duplicati-i926fa3a993ec4c7c904330dd01929cda.dindex.zip.aes (19.37 KB)
- 22 feb. 2022 15:25: Backend event: Put - Started: duplicati-i926fa3a993ec4c7c904330dd01929cda.dindex.zip.aes (19.37 KB)
- 22 feb. 2022 15:25: Backend event: Put - Completed: duplicati-icd61ce8152ab4cbcbc5ec08fd6b54b12.dindex.zip.aes (12.79 KB)
- 22 feb. 2022 15:25: Backend event: Put - Completed: duplicati-id12235b293b74bd9ab127e44fbc64949.dindex.zip.aes (2.53 KB)
- 22 feb. 2022 15:25: Backend event: Put - Started: duplicati-icd61ce8152ab4cbcbc5ec08fd6b54b12.dindex.zip.aes (12.79 KB)
- 22 feb. 2022 15:25: Backend event: Put - Started: duplicati-id12235b293b74bd9ab127e44fbc64949.dindex.zip.aes (2.53 KB)
- 22 feb. 2022 15:25: Backend event: Put - Completed: duplicati-b309c4f35930a43b887d28d8c60a575f3.dblock.zip.aes (49.36 MB)
I could find a few threads with the same problem, though the situation is different somehow. For example, other backup types, mail notifications being the evildoer (I don’t have these), other OS,…
I cannot click “Run now” to run another (2nd, incremental) backup. I haven’t rebooted my NAS or Duplicati yet, as I’m not sure this is a good idea in my situation.
Anyone having an idea what has caused this and how to solve this?
Thanks!
PS: remote volume size is 50 MB and dblock size is 1 MB.
PPS: I could find this error in stored log:
22 feb. 2022 20:38: Error in updater
System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) —> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. —> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED
at /build/mono-6.12.0.107/external/boringssl/ssl/handshake_client.c:1132
at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool)
at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebOperation.Run () [0x0009a] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebCompletionSource1[T].WaitForCompletion () [0x00094] in <6bc04dcac0a443ee834a449c98b8ed9d>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task
1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.HttpWebRequest.GetResponse () [0x00016] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebClient.GetWebResponse (System.Net.WebRequest request) [0x00000] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebClient.DownloadBits (System.Net.WebRequest request, System.IO.Stream writeStream) [0x000e6] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebClient.DownloadFile (System.Uri address, System.String fileName) [0x00088] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at System.Net.WebClient.DownloadFile (System.String address, System.String fileName) [0x00008] in <6bc04dcac0a443ee834a449c98b8ed9d>:0
at (wrapper remoting-invoke-with-check) System.Net.WebClient.DownloadFile(string,string)
at Duplicati.Library.AutoUpdater.UpdaterManager.CheckForUpdate (Duplicati.Library.AutoUpdater.ReleaseType channel) [0x000ee] in <8d4cb1693e00483189d3952c3f0ed20f>:0
Regards,
Pedro
