Slightly different ‘stuck’ issue perhaps. Current backup has been several hours (it is the initial one) and at 4:05 this morning, the dlist file was created. That also happens to be the last entry in the verbose log, yet the process still thinks it is running on ‘waiting for upload to finish’. There is no CPU/disk/network activity in task manager, so I’m a little baffled as to what is going on.
the files mentioned below in the log all exist on the backend. Everything looks like a normal completion except duplicati doesn’t think so.
FYI, I am not running as a server if that makes any difference.
from Information log
May 14, 2020 4:05 AM: Backend event: Put - Completed: duplicati-20200513T042447Z.dlist.zip.aes (6.33 MB)
May 14, 2020 4:05 AM: Backend event: Put - Completed: duplicati-if65ad0d7e5924a83bf6dc55395b462ae.dindex.zip.aes (100.65 KB)
May 14, 2020 4:05 AM: Backend event: Put - Started: duplicati-if65ad0d7e5924a83bf6dc55395b462ae.dindex.zip.aes (100.65 KB)
May 14, 2020 4:05 AM: Backend event: Put - Completed: duplicati-b589db88303d44060b885740f0d19e46e.dblock.zip.aes (44.30 MB)
May 14, 2020 4:05 AM: Backend event: Put - Started: duplicati-20200513T042447Z.dlist.zip.aes (6.33 MB)
May 14, 2020 4:05 AM: Backend event: Put - Completed: duplicati-ide5540c154b843f79aeabb2e744009e8.dindex.zip.aes (17.97 KB)
May 14, 2020 4:05 AM: Backend event: Put - Started: duplicati-ide5540c154b843f79aeabb2e744009e8.dindex.zip.aes (17.97 KB)
May 14, 2020 4:05 AM: Backend event: Put - Completed: duplicati-b21c3d0d53ba74cd38b887baa722f4c95.dblock.zip.aes (49.99 MB)
from Verbose log
May 14, 2020 4:05 AM: CommitAfterUpload took 0:00:00:00.015
May 14, 2020 4:05 AM: Starting - CommitAfterUpload
May 14, 2020 4:05 AM: Uploaded 100.65 KB in 00:00:01.2068011, 83.40 KB/s
May 14, 2020 4:05 AM: ExecuteScalarInt64: INSERT INTO “Remotevolume” (“OperationID”, “Name”, “Type”, “State”, “Size”, “VerificationCount”, “DeleteGraceTime”) VALUES (4, “duplicati-if65ad0d7e5924a83bf6dc55395b462ae.dindex.zip.aes”, “Index”, “Temporary”, -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.001
May 14, 2020 4:05 AM: Starting - ExecuteScalarInt64: INSERT INTO “Remotevolume” (“OperationID”, “Name”, “Type”, “State”, “Size”, “VerificationCount”, “DeleteGraceTime”) VALUES (4, “duplicati-if65ad0d7e5924a83bf6dc55395b462ae.dindex.zip.aes”, “Index”, “Temporary”, -1, 0, 0); SELECT last_insert_rowid();
May 14, 2020 4:05 AM: CommitAfterUpload took 0:00:00:00.014
May 14, 2020 4:05 AM: Uploaded 44.30 MB in 00:02:24.8761352, 313.10 KB/s
May 14, 2020 4:05 AM: CommitUpdateRemoteVolume took 0:00:00:00.011
May 14, 2020 4:05 AM: Starting - CommitUpdateRemoteVolume
May 14, 2020 4:05 AM: Uploading a new fileset took 0:00:02:19.174
May 14, 2020 4:05 AM: Uploaded 17.97 KB in 00:00:01.5777808, 11.39 KB/s
May 14, 2020 4:05 AM: ExecuteScalarInt64: INSERT INTO “Remotevolume” (“OperationID”, “Name”, “Type”, “State”, “Size”, “VerificationCount”, “DeleteGraceTime”) VALUES (4, “duplicati-ide5540c154b843f79aeabb2e744009e8.dindex.zip.aes”, “Index”, “Temporary”, -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.000
May 14, 2020 4:05 AM: Starting - ExecuteScalarInt64: INSERT INTO “Remotevolume” (“OperationID”, “Name”, “Type”, “State”, “Size”, “VerificationCount”, “DeleteGraceTime”) VALUES (4, “duplicati-ide5540c154b843f79aeabb2e744009e8.dindex.zip.aes”, “Index”, “Temporary”, -1, 0, 0); SELECT last_insert_rowid();
May 14, 2020 4:05 AM: CommitAfterUpload took 0:00:00:00.010
May 14, 2020 4:05 AM: Uploaded 49.99 MB in 00:02:27.5817264, 346.86 KB/s
