[Warning-Duplicati.Library.Main.Operation.BackupHandler-SnapshotFailed]: Failed to create a snapshot: Alphaleonis.Win32.Vss.VssObjectNotFoundException: The requested object does not exist
I am recently getting this error. Snapshots have worked before. Not sure what caused it. Maybe it was an automated update of windows?
This was discussed recently - look it up using forum search. So far we konw that it seems intermittent and does not seem to cause any real problems. I am not sure if anyone has reported it as a bug yet.
I’ve had some intermittent VSS errors (not this one) that began after update to Windows 10 1909.
Duplicati version didn’t change. I never figured the error out. I haven’t pursued it heavily though…
acronis vssdoctor did find a misconfigured vss shadow storage, but fixing that has not resolved the problem.
It does cause files not being backed up: outlook pst files when outlook was open during backup for example.
Every run of the backup has a warning, which is bad, as I get the habbit of ignoring the warnings.
