Versioning not advancing
Hello this my first post. I have one back that isn’t advancing, my other backup are versioning correctly I use both webui and manual.
Thank you
Welcome to the forum @jag5cof
Please check your job log, available as below in UI:
If backup finds nothing changed, no additional version is made.
from upload-unchanged-backups can override that plan if you want.
Either way, consider changing retention to hold versions to some limit.
Thank you for your response.
