after update to 2.2.0._stable I see a warning in my (unchanged) settings that with 50MB “The chosen size is outside the recommended range.“ The provided link doesn’t help as it refers to a post from last year which states “The default size is 50mb, which is chosen as a sensible default for home users with limited upload speeds.“
So what should I do about this warning?
I wondered the same and I can only assume that this is a UI glitch. It’s unlikely that the 50 MB default value is now suddenly not okay to use.
Testing on new UI, here’s where it broke:
PASS 2.1.1.101_canary_2025-08-19
FAIL 2.1.1.102_canary_2025-09-23
PASS 2.1.2.0_beta_2025-08-20
FAIL 2.1.2.1_beta_2025-10-03
When it worked, it did similarly to what old UI still does, which is complain as you type.
For example, 500MB doesn’t say anything but 5000MB gives you a warning message.
This was fixed in 2.2.0.1.
