Using Duplicati on Debian
Thank You. I install GUI now [duplicati-2.1.2.0_beta_2025-08-20-linux-x64-gui.deb]. So it’s like server? and on other machines I can install agents packages?
Regards.
Not really… each Duplicati instance is stand-alone and runs by itself.
You can run it as either the GUI (with a small tray icon) or as the Server (has a web-based UI) or as the Agent, which connects to the Duplicati console.
The different ways are described in a bit more detail here:
