Upload backup AWS S3
Hello, I’m using Duplicati to upload backups to AWS S3, all backups have Full are more than 30GB and always generate errors and do not complete the upload process.
Is there data upload limitation to S3?
Hello and welcome. S3 doesn’t have any limitations I’m aware of. Are you trying to use the archive tier? Can you show us the error messages you’re seeing?
Thanks for the feedback.
I’ll upload backups over 30GB overnight, then I’ll post the message.
I am using S3 too but to upload whole virtual machines and this works well through an AWS StorageGateway and VPN. Maybe this could help you?
So if I would upload directly to S3 it could take some time and could be interrupted. The StorageGateway is like a “cache” in between (VM from AWS running onPrem).
