I’m the poster of the thread about this issue on Opensuse. As I have upgraded in the meantime from Opensuse 15.1 to 15.2, the issue is gone for me. It seems that the rpm package released with Opensuse 15.2 can now handle Zstd. I have marked my thread as “solved”.
In my layman’s understanding:Because of the error message “Payload is Zstd” I suspect that the rpm package format used now for duplicati requires a new decompression method that the old rpmlib does not support. It seems to me that Opensuse 15.2 has now included this support.
What CentOS are you on? If on CentOS 8, maybe that upgrade would solve this without much risk?
As an aside, I don’t know if the change to zstd compression was intentional or an inadvertent change resulting from an updated Fedora (maybe Fedora 31)? Maybe we ought to try to get rpm back to xz?
Changes/Switch RPMs to zstd compression explains zstd advantages, mainly on decompression I think, however Fedora got ahead of Red Hat Enterprise Linux (and others) for awhile. I’m glad that’s being fixed, however I don’t know what else might bite in Beta if we stay zstd. Canary has a relatively small user base.
Great detail. Thanks. I will look into an upgrade of the OS to 8 in the next couple of weeks. I’m on CentOS 7 updated within the last month.
For now, Duplicati Beta is functional for me. Whatever was hanging up my backups is no longer happening, so I am not urgently pressed to go to Canary, but I still would like to be able to in the future. I will post an update here when I move forward with anything. Thanks again.
FYI I tried to simply add what any missing compression rpms but that didn’t work… I wonder if there is a need to tell rpm explicitly that zstd is available and where to look for it?
root@gilsvr:/software/Duplicati
$ l
total 92M
-rwxrw-r--. 1 gharari samba 7.2M Jan 21 2018 duplicati-2.0.2.1-2.0.2.1_beta_20170801.noarch.rpm
-rwxrw-r--. 1 gharari samba 2.1K Jan 28 2018 exclusions.txt
-rwxrw-r-- 1 gharari samba 7.7M Mar 11 2019 duplicati-2.0.4.5-2.0.4.5_beta_20181128.noarch.rpm
-rwxr----- 1 gharari samba 9.7M Jul 21 17:49 duplicati-2.0.5.1-2.0.5.1_beta_20200118.noarch.rpm
-rwxr----- 1 gharari samba 45M Aug 20 12:31 duplicati-master.zip
drwxr-x--- 13 root root 4.0K Aug 20 12:32 duplicati-master
-rwxr----- 1 gharari samba 23M Aug 20 19:22 duplicati-2.0.5.110-2.0.5.110_canary_20200810.noarch.rpm
$ rpm -qp --qf ‘%{PAYLOADCOMPRESSOR}\n’ duplicati-2.0.5.1-2.0.5.1_beta_20200118.noarch.rpm
‘xzn’
$ rpm -qp --qf ‘%{PAYLOADCOMPRESSOR}\n’ duplicati-2.0.5.110-2.0.5.110_canary_20200810.noarch.rpm
‘zstdn’
$ which xzn
/usr/bin/which: no xzn in (/root/perl5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/home/gharari/scripts:/home/gharari/bin:/usr/sbin:/bin:/usr/local/bin:/root/bin)
$ which xz
/usr/bin/xz
$ which zip
/usr/bin/zip
$ rpm -qa|egrep -i "xz|zstd"
libzstd-1.4.5-3.el7.x86_64
xz-libs-5.2.2-1.el7.x86_64
xz-5.2.2-1.el7.x86_64
$ yum list available *zstd*
Loaded plugins: fastestmirror, product-id, search-disabled-repos, subscription-manager
This system is not registered with an entitlement server. You can use subscription-manager to register.
Determining fastest mirrors
* base: mirror.den01.meanservers.net
* centos-sclo-rh: mirrors.sonic.net
* centos-sclo-sclo: mirrors.raystedman.org
* epel: d2lzkl7pfhq30w.cloudfront.net
* extras: mirror.den01.meanservers.net
* nux-dextop: mirror.li.nux.ro
* updates: repos-tx.psychz.net
Available Packages
libknet1-compress-zstd-plugin.x86_64 1.18-1.el7 epel
libzstd-devel.x86_64 1.4.5-3.el7 epel
libzstd-static.x86_64 1.4.5-3.el7 epel
php-zstd.x86_64 0.9.0-1.el7 epel
php-zstd-devel.x86_64 0.9.0-1.el7 epel
zstd.x86_64 1.4.5-3.el7 epel
$ yum install zstd libzstd*
Loading mirror speeds from cached hostfile
epel/x86_64/metalink | 18 kB 00:00:00
base | 3.6 kB 00:00:00
centos-sclo-rh | 3.0 kB 00:00:00
centos-sclo-sclo | 3.0 kB 00:00:00
docker-ce-stable | 3.5 kB 00:00:00
epel | 4.7 kB 00:00:00
extras | 2.9 kB 00:00:00
mono-centos7-stable | 2.9 kB 00:00:00
nux-dextop | 2.9 kB 00:00:00
updates | 2.9 kB 00:00:00
(1/5): updates/7/x86_64/primary_db | 4.5 MB 00:00:00
(2/5): epel/x86_64/group_gz | 95 kB 00:00:00
epel/x86_64/updateinfo FAILED
https://mirrors.sonic.net/epel/7/x86_64/repodata/39992ea5beec37b8092b0caa1d478075a8531053111b4a1c713aad3302450bdd-updateinfo.xml.bz2: [Errno 14] HTTPS Error 404 - Not Found B --:--:-- ETA
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
(3/5): centos-sclo-rh/x86_64/primary_db | 2.9 MB 00:00:00
(4/5): epel/x86_64/updateinfo | 1.0 MB 00:00:00
(5/5): epel/x86_64/primary_db | 6.9 MB 00:00:01
Package libzstd-1.4.5-3.el7.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package libzstd-devel.x86_64 0:1.4.5-3.el7 will be installed
---> Package libzstd-static.x86_64 0:1.4.5-3.el7 will be installed
---> Package zstd.x86_64 0:1.4.5-3.el7 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
libzstd-devel x86_64 1.4.5-3.el7 epel 41 k
libzstd-static x86_64 1.4.5-3.el7 epel 335 k
zstd x86_64 1.4.5-3.el7 epel 583 k
Transaction Summary
Install 3 Packages
Total download size: 959 k
Installed size: 2.8 M
Downloading packages:
(1/3): libzstd-devel-1.4.5-3.el7.x86_64.rpm | 41 kB 00:00:00
(2/3): libzstd-static-1.4.5-3.el7.x86_64.rpm | 335 kB 00:00:00
(3/3): zstd-1.4.5-3.el7.x86_64.rpm | 583 kB 00:00:00
Total 1.4 MB/s | 959 kB 00:00:00
Running transaction test
Transaction test succeeded
Running transaction
Installing : libzstd-devel-1.4.5-3.el7.x86_64 1/3
Installing : libzstd-static-1.4.5-3.el7.x86_64 2/3
Installing : zstd-1.4.5-3.el7.x86_64 3/3
Verifying : libzstd-devel-1.4.5-3.el7.x86_64 1/3
Verifying : libzstd-static-1.4.5-3.el7.x86_64 2/3
Verifying : zstd-1.4.5-3.el7.x86_64 3/3
Installed:
libzstd-devel.x86_64 0:1.4.5-3.el7 libzstd-static.x86_64 0:1.4.5-3.el7 zstd.x86_64 0:1.4.5-3.el7
Complete!
$ man rpm
$ rpm -Uv --test duplicati-2.0.5.110-2.0.5.110_canary_20200810.noarch.rpm
error: Failed dependencies:
rpmlib(PayloadIsZstd) <= 5.4.18-1 is needed by duplicati-2.0.5.110-2.0.5.110_canary_20200810.noarch
