Updating to 2.3.0.3 (Stable) breaks all connections
Just updated Duplicati to 2.3.0.3 stable.
I use it in portable mode: start Duplicati.GUI.TrayIcon.exe --portable-mode)
Didn’t change anything in config, but now all S3 and Storj connections are broken.
Just clicking “Test Now” for S3 (amazon aws) returns this error:
Test connection failed
Error
 listing content: Failed to resolve AWS credentials. The credential
providers used to search for credentials returned the following errors:
Exception 1 of 4: The environment variables
AWS_ACCESS_KEY_ID/AWS_SECRET_ACCESS_KEY/AWS_SESSION_TOKEN were not set
with AWS credentials.
Exception 2 of 4: The webIdentityTokenFile must be an absolute path.
(Parameter 'webIdentityTokenFile')
Exception 3 of 4: Unable to find the "default" profile.
Exception 4 of 4: Failed to connect to EC2 instance metadata to retrieve
 credentials: Unable to get IAM security credentials from EC2 Instance
Metadata Service..
My s3 connection in the config looks:
"TargetURL": "s3s://mys3bak/BAK?``s3-server-name=s3.amazonaws.com``&s3-location-constraint=EU&s3-storage-class=&s3-client=aws&auth-username=***&auth-password=***",
Also It reintroduced the old STORJ bug where Access Grant only works in the old UI.
In the NEW UI it returns error:
NULL: api_key
	main.uplink_config_request_access_with_passphrase:26
	_cgoexp_128b453d6672_uplink_config_request_access_with_passphrase:738
	runtime.cgocallbackg1:446
	runtime.cgocallbackg:350
	runtime.cgocallback:1084
Access Grant is selected, but it the new UI it tries to use API. This bug was reported and fixed in previous version:
