Unintuitive behavior with hidden folders
Not sure if a feature request or a bug report - I am backing a folder which has a hidden sub-folder (one starting with a period ‘.’).
If I select the parent, the hidden folder is backed up as well. This I suppose is expected.
However, what was a little surprising is that when I expand the list of folders - the subfolder doesn’t show up. So if I deselect the parent and click all the subfolders then the hidden folder isn’t backed up.
This was a bit unintuitive and surprising since the sum of the size of parts (subfolders) isn’t equal to the size of parent.
I think the way to resolve is to show hidden folders in the listing of subfolders (or at minimum have tick box to allow the hidden to be shown)
Duplicati already has that :slight_smile:
Guess I am a blind dumbass :stuck_out_tongue: Thanks for the info.
