and again a big problem, I get the impression that the utility is falling apart. There are 1000 errors in it, if you watch my feedbacks.
I have never had such a mistake, but today it has appeared. There was a simple backup like I always did.
errors
Unexpected EOF or 0 bytes from transport stream.
System.IO.IOException: Unexpected EOF or 0 bytes from the transport stream.
in Duplicati.Library.Main.BackendManager.List ()
in Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (BackendManager backend, Options options, Local Database database, IBackendWriter log, String protectedfile)
in Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (BackendManager backend, Options options, Local Database database, IBackendWriter log, String protectedfile)
in Duplicati.Library.Main.Operation.BackupHandler.PostBackupVerification ()
in Duplicati.Library.Main.Operation.BackupHandler. <RunAsync> d__19.MoveNext ()
--- End of stack trace from previous location where exception occurred ---
in System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw ()
in CoCoL.ChannelExtensions.WaitForTaskOrThrow (Task task)
in Duplicati.Library.Main.Controller. <> c__DisplayClass13_0. <Backup> b__0 (BackupResults result)
in Duplicati.Library.Main.Controller.RunAction [T] (T result, String [] & paths, IFilter & filter, Action`1 method)
in Duplicati.Library.Main.Controller.Backup (String [] inputs sources, IFilter filter)
in Duplicati.Server.Runner.Run (IRunnerData data, Boolean fromQueue)
