Hello,
I just installed Duplicati on my Debian 11 server, using the docs.
I followed all the steps, but every times I try to start Duplicati, it fail (sudo systemctl start duplicati.service
Here is the result of sudo systemctl status duplicati.service
● duplicati.service - Duplicati web-server
Loaded: loaded (/etc/systemd/system/duplicati.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2023-11-23 11:24:15 UTC; 6s ago
Process: 821772 ExecStart=/usr/bin/duplicati-server $DAEMON_OPTS (code=exited, status=203/EXEC)
Main PID: 821772 (code=exited, status=203/EXEC)
CPU: 1ms
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: duplicati.service: Main process exited, code=exited, status=203/EXEC
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: duplicati.service: Failed with result 'exit-code'.
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: duplicati.service: Scheduled restart job, restart counter is at 5.
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: Stopped Duplicati web-server.
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: duplicati.service: Start request repeated too quickly.
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: Failed to start Duplicati web-server.
And here sudo journalctl -e -u duplicati
Nov 23 11:24:15 vps-77ab1b3c systemd[1]: Started Duplicati web-server.
Nov 23 11:24:15 vps-77ab1b3c systemd[821772]: duplicati.service: Failed to locate executable /usr/bin/duplicati-server: No such file or directory
Nov 23 11:24:15 vps-77ab1b3c systemd[821772]: duplicati.service: Failed at step EXEC spawning /usr/bin/duplicati-server: No such file or directory
Thank you very much for your help!
