Unable to rebuild database when a specific dblock is missing
I’m trying to recover from a disaster.
Some shenanigans happened when moving the files to a new machine, and attempted to move the backup to contiinue doing backups of the new machine on top of the backups of the old machine (That is to say, one day the old machine no longer does backups, the next day the new machine does backups on top). Back then (october 2024) I did something wrong (not sure what, with the migration I had a lot going on in my life), and when I realized that something had gone catastrophically wrong, I did the easy temporary fix: New backup job to a new location, and keep a copy of the old backup so I could try to fix them later.
Now is later.
This is what I have in the target directory (external drive, Windows OS) example path of backup files: F:\BackupJobs\OldBackup
  • 103 dlist files
  • 242 dblock files
  • 216 dindex files
Backup setting (deleted some useless stuff like email reporting and anonimized paths)
"C:\Program Files\Duplicati 2\Duplicati.CommandLine.exe" backup "file://F:\BackupJobs\OldBackup\\" "C:\Users\Account\Folder1\\" "C:\Users\Account\Folder2\\" "%MSSQL%" --asynchronous-concurrent-upload-limit=1 --allow-missing-source=true --backup-name="OldBackup" --dbpath="C:\Path\To\Nonexistent\Database.sqlite" --backup-id=DB-2 --compression-module=zip --dblock-size=2GB --retention-policy="2W:1D,4W:1W,12M:1M,5Y:1Y" --no-encryption=True --snapshot-policy=Required --backup-test-percentage=5 --symlink-policy=Store --synchronous-upload=true --run-script-before-required="C:\Path\To\Scripts\DuplicatiScripts.cmd" --run-script-after="C:\Path\To\Scripts\DuplicatiScripts.cmd" --tempdir="R:\Duplicati\\" --asynchronous-upload-folder="R:\Duplicati\\" --disable-module=console-password-input
(The before and after script creates and deletes a ramdisk in R so backup operations dont wear out the drive, I don’t think that’s relevant here)
What I believe might be relevant is:
--dblock-size=2GB
The old database was missing, so I recreated the backup job in duplicati web GUI and tried to rebuild it, but after a while (after all, the whole backup size is ~380GiB, and the max dblock size is ~2GB), it failed saying that a dblock was missing.
So I tried to use the repair command with the --rebuild-missing-dblock-files option:
"c:\Program Files\Duplicati 2\Duplicati.CommandLine.exe" repair "F:\BackupJobs\OldBackup" --rebuild-missing-dblock-files --tempdir=R:\Duplicati --no-encryption
This was the final output (“Archivo no encontrado” means “File not found”):
The operation Repair has failed => Archivo no encontrado: Could not find file '\\?\F:\BackupJobs\OldBackup\duplicati-b159818b633b24f32bcfa362fea7132a8.dblock.zip'.
ErrorID: FileMissing
This is the whole console output it gave while working until it failed:
Console Log
C:\Windows\system32>"c:\Program Files\Duplicati 2\Duplicati.CommandLine.exe" repair "F:\BackupJobs\OldBackup" --rebuild-missing-dblock-files --tempdir=R:\Duplicati --no-encryption
  Listing remote folder ...
  Downloading file duplicati-20210822T235733Z.dlist.zip (10,36 MiB) ...
  Downloading file duplicati-20220708T200001Z.dlist.zip (12,71 MiB) ...
  Downloading file duplicati-20230202T200002Z.dlist.zip (12,68 MiB) ...
  Downloading file duplicati-20230731T200027Z.dlist.zip (23,21 MiB) ...
  Downloading file duplicati-20231021T200012Z.dlist.zip (44,56 MiB) ...
  Downloading file duplicati-20231021T200013Z.dlist.zip (28,95 MiB) ...
  Downloading file duplicati-20231122T200017Z.dlist.zip (44,82 MiB) ...
  Downloading file duplicati-20231122T200018Z.dlist.zip (29,21 MiB) ...
  Downloading file duplicati-20240102T140131Z.dlist.zip (45,57 MiB) ...
  Downloading file duplicati-20240102T140132Z.dlist.zip (29,66 MiB) ...
  Downloading file duplicati-20240210T200015Z.dlist.zip (45,28 MiB) ...
  Downloading file duplicati-20240210T200016Z.dlist.zip (30,36 MiB) ...
  Downloading file duplicati-20240313T200020Z.dlist.zip (45,85 MiB) ...
  Downloading file duplicati-20240313T200021Z.dlist.zip (30,99 MiB) ...
  Downloading file duplicati-20240414T200012Z.dlist.zip (46,36 MiB) ...
  Downloading file duplicati-20240414T200013Z.dlist.zip (30,64 MiB) ...
  Downloading file duplicati-20240522T200013Z.dlist.zip (48,23 MiB) ...
  Downloading file duplicati-20240522T200014Z.dlist.zip (29,79 MiB) ...
  Downloading file duplicati-20240624T200021Z.dlist.zip (49,21 MiB) ...
  Downloading file duplicati-20240624T200022Z.dlist.zip (31,19 MiB) ...
  Downloading file duplicati-20240802T200018Z.dlist.zip (52,95 MiB) ...
  Downloading file duplicati-20240802T200019Z.dlist.zip (34,17 MiB) ...
  Downloading file duplicati-20240901T200005Z.dlist.zip (47,80 MiB) ...
  Downloading file duplicati-20240901T200006Z.dlist.zip (33,98 MiB) ...
  Downloading file duplicati-20240909T200005Z.dlist.zip (49,64 MiB) ...
  Downloading file duplicati-20240909T200006Z.dlist.zip (35,82 MiB) ...
  Downloading file duplicati-20240910T200005Z.dlist.zip (49,69 MiB) ...
  Downloading file duplicati-20240910T200006Z.dlist.zip (35,88 MiB) ...
  Downloading file duplicati-20240911T200006Z.dlist.zip (47,47 MiB) ...
  Downloading file duplicati-20240911T200007Z.dlist.zip (33,72 MiB) ...
  Downloading file duplicati-20240912T200011Z.dlist.zip (47,53 MiB) ...
  Downloading file duplicati-20240912T200012Z.dlist.zip (33,77 MiB) ...
  Downloading file duplicati-20240914T200006Z.dlist.zip (47,53 MiB) ...
  Downloading file duplicati-20240914T200007Z.dlist.zip (33,77 MiB) ...
  Downloading file duplicati-20240915T200006Z.dlist.zip (47,53 MiB) ...
  Downloading file duplicati-20240915T200007Z.dlist.zip (33,77 MiB) ...
  Downloading file duplicati-20240916T200006Z.dlist.zip (47,60 MiB) ...
  Downloading file duplicati-20240916T200007Z.dlist.zip (33,85 MiB) ...
  Downloading file duplicati-20240917T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240918T200006Z.dlist.zip (47,62 MiB) ...
  Downloading file duplicati-20240918T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240919T200006Z.dlist.zip (47,62 MiB) ...
  Downloading file duplicati-20240919T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240920T200006Z.dlist.zip (47,62 MiB) ...
  Downloading file duplicati-20240920T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240921T200006Z.dlist.zip (47,62 MiB) ...
  Downloading file duplicati-20240921T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240922T200006Z.dlist.zip (47,62 MiB) ...
  Downloading file duplicati-20240922T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20240923T200006Z.dlist.zip (47,70 MiB) ...
  Downloading file duplicati-20240923T200007Z.dlist.zip (33,95 MiB) ...
  Downloading file duplicati-20240924T200006Z.dlist.zip (47,73 MiB) ...
  Downloading file duplicati-20240924T200007Z.dlist.zip (33,97 MiB) ...
  Downloading file duplicati-20240925T200006Z.dlist.zip (47,75 MiB) ...
  Downloading file duplicati-20240925T200007Z.dlist.zip (33,99 MiB) ...
  Downloading file duplicati-20240926T200006Z.dlist.zip (47,51 MiB) ...
  Downloading file duplicati-20240926T200007Z.dlist.zip (33,76 MiB) ...
  Downloading file duplicati-20240927T200006Z.dlist.zip (47,52 MiB) ...
  Downloading file duplicati-20240927T200007Z.dlist.zip (33,76 MiB) ...
  Downloading file duplicati-20240928T200006Z.dlist.zip (47,52 MiB) ...
  Downloading file duplicati-20240928T200007Z.dlist.zip (33,76 MiB) ...
  Downloading file duplicati-20240929T200006Z.dlist.zip (47,52 MiB) ...
  Downloading file duplicati-20240929T200007Z.dlist.zip (33,76 MiB) ...
  Downloading file duplicati-20240930T200006Z.dlist.zip (47,53 MiB) ...
  Downloading file duplicati-20240930T200007Z.dlist.zip (33,77 MiB) ...
  Downloading file duplicati-20241001T200006Z.dlist.zip (47,57 MiB) ...
  Downloading file duplicati-20241001T200007Z.dlist.zip (33,86 MiB) ...
  Downloading file duplicati-20241002T200043Z.dlist.zip (47,64 MiB) ...
  Downloading file duplicati-20241002T200044Z.dlist.zip (33,96 MiB) ...
  Downloading file duplicati-20241003T200006Z.dlist.zip (47,66 MiB) ...
  Downloading file duplicati-20241003T200007Z.dlist.zip (33,98 MiB) ...
  Downloading file duplicati-20241004T200013Z.dlist.zip (48,38 MiB) ...
  Downloading file duplicati-20241004T200014Z.dlist.zip (34,70 MiB) ...
  Downloading file duplicati-20241005T200006Z.dlist.zip (48,38 MiB) ...
  Downloading file duplicati-20241005T200007Z.dlist.zip (34,70 MiB) ...
  Downloading file duplicati-20241006T200006Z.dlist.zip (48,38 MiB) ...
  Downloading file duplicati-20241006T200007Z.dlist.zip (34,70 MiB) ...
  Downloading file duplicati-20241007T200006Z.dlist.zip (47,75 MiB) ...
  Downloading file duplicati-20241007T200007Z.dlist.zip (34,06 MiB) ...
  Downloading file duplicati-20241008T200006Z.dlist.zip (47,75 MiB) ...
  Downloading file duplicati-20241008T200007Z.dlist.zip (34,07 MiB) ...
  Downloading file duplicati-20241009T200039Z.dlist.zip (47,80 MiB) ...
  Downloading file duplicati-20241009T200040Z.dlist.zip (34,12 MiB) ...
  Downloading file duplicati-20241011T200006Z.dlist.zip (47,84 MiB) ...
  Downloading file duplicati-20241011T200007Z.dlist.zip (34,15 MiB) ...
  Downloading file duplicati-20241012T200006Z.dlist.zip (47,84 MiB) ...
  Downloading file duplicati-20241012T200007Z.dlist.zip (34,15 MiB) ...
  Downloading file duplicati-20241013T200006Z.dlist.zip (47,84 MiB) ...
  Downloading file duplicati-20241013T200007Z.dlist.zip (34,15 MiB) ...
  Downloading file duplicati-20241014T200006Z.dlist.zip (48,33 MiB) ...
  Downloading file duplicati-20241014T200007Z.dlist.zip (34,64 MiB) ...
  Downloading file duplicati-20241015T200005Z.dlist.zip (48,37 MiB) ...
  Downloading file duplicati-20241015T200006Z.dlist.zip (34,69 MiB) ...
  Downloading file duplicati-20241016T200006Z.dlist.zip (48,45 MiB) ...
  Downloading file duplicati-20241016T200007Z.dlist.zip (34,77 MiB) ...
  Downloading file duplicati-20241017T200006Z.dlist.zip (48,51 MiB) ...
  Downloading file duplicati-20241017T200007Z.dlist.zip (34,81 MiB) ...
  Downloading file duplicati-20241018T200006Z.dlist.zip (48,53 MiB) ...
  Downloading file duplicati-20241018T200007Z.dlist.zip (34,83 MiB) ...
  Downloading file duplicati-20241019T200006Z.dlist.zip (48,53 MiB) ...
  Downloading file duplicati-20241019T200007Z.dlist.zip (34,83 MiB) ...
  Downloading file duplicati-20241020T200006Z.dlist.zip (48,53 MiB) ...
  Downloading file duplicati-20241020T200007Z.dlist.zip (34,83 MiB) ...
  Downloading file duplicati-i02f3af9e3e674f5bbcc04db148b504ca.dindex.zip (1,39 MiB) ...
  Downloading file duplicati-i039d35b9c06d44a68d883edf3cdbf933.dindex.zip (1,29 MiB) ...
  Downloading file duplicati-i04e13998c9c2478fb8b3c13573379377.dindex.zip (624,92 KiB) ...
  Downloading file duplicati-i0833003799f44d58968d4d5d063a3b95.dindex.zip (2,74 MiB) ...
  Downloading file duplicati-i0a96e8203c814a0fadc68634108ceb8f.dindex.zip (3,42 MiB) ...
  Downloading file duplicati-i0a9fdc7be0c04fd28f67be0e3816a268.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-i0bf4b40f7ffd48128aa57b299b98cf38.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i0cc924549c7e4a16a243c1d08046ca0b.dindex.zip (1,56 MiB) ...
  Downloading file duplicati-i0f0ef8de9c634c5e9bef3cd2c1f97923.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i0f0feb57eae948a8b7a025d3a6cc6808.dindex.zip (1,34 MiB) ...
Remote file referenced as duplicati-b159818b633b24f32bcfa362fea7132a8.dblock.zip by duplicati-i0f0ef8de9c634c5e9bef3cd2c1f97923.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-i0f52b4a6c66a45a096b87437bc4fa639.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i1126e2d3011b493fbc5a8732f4198995.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i11c23aa66be942d481045032fa874cbb.dindex.zip (1,50 MiB) ...
  Downloading file duplicati-i1297833eee704416ae5bbbb0ba183126.dindex.zip (606,06 KiB) ...
  Downloading file duplicati-i135171992dde47f5938393fee0a8517b.dindex.zip (1,64 MiB) ...
  Downloading file duplicati-i13a7ced4a3a34bf58b26df1925690109.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i13b812b4f77c47d0b2ceb1a9cb9a9ac7.dindex.zip (1,34 MiB) ...
  Downloading file duplicati-i1442d392803940edaa3190b5027c24dd.dindex.zip (969,28 KiB) ...
  Downloading file duplicati-i14aaec5f98b24e4b86d484f82ba23fdc.dindex.zip (1,32 MiB) ...
  Downloading file duplicati-i15ae9cbf97eb441387d8df1e7d9700b0.dindex.zip (1,30 MiB) ...
Remote file referenced as duplicati-b4986cd0e52fd4a4a861a994fe61191cd.dblock.zip by duplicati-i14aaec5f98b24e4b86d484f82ba23fdc.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-i161900761ea24938901efb40607af81d.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i1710d3c5f3d54ea2b6e049832b1b8076.dindex.zip (1,56 MiB) ...
  Downloading file duplicati-i1bb2b937b5ac4b5ea9fbaf916bc8770c.dindex.zip (3,92 MiB) ...
  Downloading file duplicati-i1beffe00a7724948a4422f2444538770.dindex.zip (617,17 KiB) ...
  Downloading file duplicati-i1e1cf71398a44e4f9a17e77c859cbfe0.dindex.zip (643,80 KiB) ...
  Downloading file duplicati-i1e6ac14094cd4099a7f3f8394e37ced3.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i1e8558793f68488e99b876daa8a1dfc6.dindex.zip (632,96 KiB) ...
  Downloading file duplicati-i213b95e29891484c9e8e972d389017db.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-i217cccb9a4f64aaa9a06c461e896cd2f.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i2345cfaad28e4d7581acbcd2aed5d9b9.dindex.zip (594,39 KiB) ...
  Downloading file duplicati-i23f3a71ba3b34666a3297cd6cfe78760.dindex.zip (1,32 MiB) ...
  Downloading file duplicati-i255ebc69231c4c93be46844335801a24.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-i25dffd5326d74f01b14a6778ee323854.dindex.zip (1,52 MiB) ...
  Downloading file duplicati-i273cf0e8160843dc96e6e1859375c598.dindex.zip (1,44 MiB) ...
  Downloading file duplicati-i282d2435ac50421382b73dc345fa7b04.dindex.zip (1,41 MiB) ...
  Downloading file duplicati-i28ce52c0c48441a2b81281abfe7bb071.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i2979b4100792435fa03a1a50cc515b6c.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i2a8c381a92024ad089dbce67ca8685d1.dindex.zip (14,96 MiB) ...
  Downloading file duplicati-i2c3de12e0b0640c5aeaec87fc7434af5.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i3184ce1d2397413887d4385ff69f5b33.dindex.zip (1,39 MiB) ...
  Downloading file duplicati-i33db4dec9a7d4f458bef8ef30974b9b6.dindex.zip (802,56 KiB) ...
  Downloading file duplicati-i35f76ab32b4f4b35adee127cfa3eb13d.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i391f2654260c48c6a845f58841c2d8f6.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i39d9da770054421494fb7c2efc463d98.dindex.zip (1,67 MiB) ...
  Downloading file duplicati-i3a85905c6b1747a48f4c0b84f540dc9a.dindex.zip (4,05 MiB) ...
  Downloading file duplicati-i3b9d8943946840aca901015682cd1014.dindex.zip (1,44 MiB) ...
  Downloading file duplicati-i3beef5749bdb431e9866a05b0573eeee.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i3c6d459edda446dbb2959205e231b7db.dindex.zip (832,38 KiB) ...
  Downloading file duplicati-i3ca73a1e588c42e9987c1eb4fa92ff3d.dindex.zip (689,08 KiB) ...
  Downloading file duplicati-i3d66f2a2a4864f62b3771216b8351a87.dindex.zip (1,42 MiB) ...
  Downloading file duplicati-i3e80e84d969a44dab16997b756b7b8b1.dindex.zip (1,35 MiB) ...
  Downloading file duplicati-i3ec7da666dcc4bf3a1f9e752ab316ba6.dindex.zip (604,82 KiB) ...
  Downloading file duplicati-i3f84f1710fed450f86cf6b661e894b88.dindex.zip (643,37 KiB) ...
  Downloading file duplicati-i4360582989fa4da586ce975fdf0cfab4.dindex.zip (1,37 MiB) ...
  Downloading file duplicati-i44892d6c20ae48828c0d4bf63e507205.dindex.zip (1,69 MiB) ...
  Downloading file duplicati-i44929585a4eb4a109ea5fba0b47c31f5.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i46453c9e8f684703aa84048930b97f50.dindex.zip (592,36 KiB) ...
  Downloading file duplicati-i4653a2d64aea47b6ab4b7d1e08440394.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-i473e4a4358a34806a3d1240869781b27.dindex.zip (758,79 KiB) ...
  Downloading file duplicati-i479e90653bd342f18ed5b73e7ae3e36f.dindex.zip (1,95 MiB) ...
  Downloading file duplicati-i494b6fa8934c4c26acde562eccea39cc.dindex.zip (1,27 MiB) ...
  Downloading file duplicati-i4a11d26499c949748d736d95035815a7.dindex.zip (3,86 MiB) ...
Remote file referenced as duplicati-b0fdc8b06407f4338af920db932554793.dblock.zip by duplicati-i494b6fa8934c4c26acde562eccea39cc.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-i4a82a2be638243d7ae47922f33764c44.dindex.zip (2,48 MiB) ...
  Downloading file duplicati-i4b320e58ff0e4bd99c0350c6236de2f6.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i4b4feebc97b94a01bcb207991d235556.dindex.zip (1,71 MiB) ...
  Downloading file duplicati-i4c081fa328f7495ebc17e97432edf731.dindex.zip (1,89 MiB) ...
  Downloading file duplicati-i4c7b25e77de2474192a783f5900b9cb7.dindex.zip (1,30 MiB) ...
Remote file referenced as duplicati-bf3dac96745c046f1b175b5d2c3350d39.dblock.zip by duplicati-i4c081fa328f7495ebc17e97432edf731.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-i4f4be3cae57844dba69626fa7f1c1d27.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i4fc4d70906d54f0eb2033425ef5c4563.dindex.zip (1,98 MiB) ...
  Downloading file duplicati-i5259fddde0a647e8adcd485f4aa6201a.dindex.zip (1,70 MiB) ...
  Downloading file duplicati-i52d4fb3edee640d7937e7e07eff6dfbb.dindex.zip (496,37 KiB) ...
  Downloading file duplicati-i543fb82fe4a443ee811e3f0904229b3a.dindex.zip (2,16 MiB) ...
  Downloading file duplicati-i5490bb130faa46a18c750eee0559dbaa.dindex.zip (3,94 MiB) ...
  Downloading file duplicati-i577515d5af164afa87ef33ed50725273.dindex.zip (1,27 MiB) ...
  Downloading file duplicati-i586944aac52449f281a12b2707e8a5a7.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i58a86507fb8d4e69bffdd468c300630e.dindex.zip (1,41 MiB) ...
  Downloading file duplicati-i5ce763349e5c455eb625bcaf9dc766a6.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i606d37325a0a40d69a44e77dfd5fd98b.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i619a16b04da6487a838eefacc20e2f83.dindex.zip (1,56 MiB) ...
  Downloading file duplicati-i61ae5382ca134674b5c41cf4aa0519f9.dindex.zip (2,70 MiB) ...
  Downloading file duplicati-i62816fbd5f2c4b5bb86d3423dd8e5754.dindex.zip (1,34 MiB) ...
  Downloading file duplicati-i62d28a0cb8674101ae41d233b918b9d8.dindex.zip (1,35 MiB) ...
  Downloading file duplicati-i641544033a3240fc944d5faa9599141a.dindex.zip (2,57 MiB) ...
  Downloading file duplicati-i647b71da80d849208b1b9aa336bbdc9a.dindex.zip (3,11 MiB) ...
  Downloading file duplicati-i64a2a19fdfa2462a9dbdb51373aa6a47.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i66c4733d790443b0a0410d92d999a28b.dindex.zip (2,75 MiB) ...
  Downloading file duplicati-i6795cc1c5cc14b8c9e3b4aa183116849.dindex.zip (776,59 KiB) ...
  Downloading file duplicati-i6acce8de76254ca6b8c787036f07f452.dindex.zip (2,28 MiB) ...
  Downloading file duplicati-i6ada64d8760742039965029d8e1967f4.dindex.zip (1,43 MiB) ...
  Downloading file duplicati-i6b4304fbb4fd41e4a2f2f7aa4f66e203.dindex.zip (1,32 MiB) ...
  Downloading file duplicati-i6b6c25798fc145d7959afa8d95e04593.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i6cf5753461744ffeb0e7e18fed026c06.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i6d0ac251c09c460fb43e729bd926a014.dindex.zip (660,76 KiB) ...
  Downloading file duplicati-i70ab70a860974390a82b2d4354b5cf97.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i7151ec96ca164a6a836f57dda9d36cd9.dindex.zip (1,17 MiB) ...
  Downloading file duplicati-i72a67cdb81744b548050b58a7b9f87ec.dindex.zip (1,28 MiB) ...
  Downloading file duplicati-i74a30a03031943cb9fec34bf5dbc42d3.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i754ed6ca6fc84ab8a7907b2fe7709f9f.dindex.zip (1,70 MiB) ...
  Downloading file duplicati-i75a75361cf524b0dbd9418c8b5a90c32.dindex.zip (16,49 MiB) ...
  Downloading file duplicati-i7744c894f40f4d5eb31a329229b70e9e.dindex.zip (1,57 MiB) ...
  Downloading file duplicati-i77839dfe3ac94cadb1cb26e9ab08baa1.dindex.zip (604,96 KiB) ...
  Downloading file duplicati-i78169535a2484ebb9f2fe5000aac566a.dindex.zip (753,27 KiB) ...
  Downloading file duplicati-i7abbb5c598134f198f96a7dd4a1ace9b.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-i7ae3e0f89990429a82a406e9a418fcf3.dindex.zip (2,15 MiB) ...
  Downloading file duplicati-i7eb84d6d16a74aff8bf981e5a2c71ef1.dindex.zip (1,50 MiB) ...
  Downloading file duplicati-i802711a7d6eb4b56aaf0915d1d5ca741.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i80f3b64707f546659760ee2ccbf6fb07.dindex.zip (1,59 MiB) ...
  Downloading file duplicati-i827a4803f1e34141a69f6f0221130c7a.dindex.zip (1,67 MiB) ...
  Downloading file duplicati-i83134374a3e74312aafbda652150f1f9.dindex.zip (1,57 MiB) ...
  Downloading file duplicati-i834f443607e34beeb9f2d0be3ac4196c.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i87e8cbb66ff541f0abe0afbfcbb1a67c.dindex.zip (1,28 MiB) ...
  Downloading file duplicati-i884f8accd32145caab756b9878723c6e.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i8958be4a0755401da32fcece34856086.dindex.zip (1,72 MiB) ...
  Downloading file duplicati-i8d637235989744619fd2a9da9c57320b.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i90364e0dbd9e4630ad6476583ca7f6cf.dindex.zip (664,77 KiB) ...
  Downloading file duplicati-i928971711e204d6d87bdf6966e1dab2f.dindex.zip (1,52 MiB) ...
  Downloading file duplicati-i931c3c3d9b30483eaf6d5ec277a1398e.dindex.zip (1,38 MiB) ...
  Downloading file duplicati-i93fbbdfc863d4f329f6213ad173288b0.dindex.zip (617,87 KiB) ...
  Downloading file duplicati-i94e5a2387dd345819624a8b788a3c109.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-i962c25baa5c0439db7c788c24a2c6b51.dindex.zip (735,66 KiB) ...
  Downloading file duplicati-i965e81b74e114bfbaca4a86314a21dae.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-i972691b627ee453e9a03e26f52ea1a13.dindex.zip (797,74 KiB) ...
Remote file referenced as duplicati-b06458b86c47a4ac4ab08a4f33d3d45ca.dblock.zip by duplicati-i965e81b74e114bfbaca4a86314a21dae.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-i976874e1098e45fda5da8dfc463a62a2.dindex.zip (1,71 MiB) ...
  Downloading file duplicati-i9792c29aebe7494fac56427a6a212ed7.dindex.zip (1,67 MiB) ...
  Downloading file duplicati-i9ae2c1f7932d45b4beedb51ed4223684.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-i9c42222fd5064f5f932e2ecf4d60e397.dindex.zip (1,57 MiB) ...
  Downloading file duplicati-i9cd48e9bf2304ff7af398d4979cd9e58.dindex.zip (588,15 KiB) ...
  Downloading file duplicati-i9d0aa16fa9ac4af0930f2cc6d47e92d0.dindex.zip (1,35 MiB) ...
  Downloading file duplicati-i9d6d2fa55d234a16bcb14e87b401563d.dindex.zip (416,19 KiB) ...
  Downloading file duplicati-i9f535b8ecb8e4d1eb66330623448b100.dindex.zip (1,49 MiB) ...
  Downloading file duplicati-i9fa8841c76a44b41a87d9fe113c252a6.dindex.zip (323,40 KiB) ...
  Downloading file duplicati-ia0b3cf663cbe499fa82b1560dc5bffe2.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-ia1f4302aef7e4e8fb684ad44ac628a09.dindex.zip (1,95 MiB) ...
Remote file referenced as duplicati-b8a4a5dcdb4c245c09b0a29b761ad23b3.dblock.zip by duplicati-ia0b3cf663cbe499fa82b1560dc5bffe2.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-ia40f564b395f48a6837441b03abfbb6a.dindex.zip (1,45 MiB) ...
Remote file referenced as duplicati-b35790412678244bdb8eb22f056e4c039.dblock.zip by duplicati-ia1f4302aef7e4e8fb684ad44ac628a09.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-ia4b5cb58029448c7b09a295a55c452a5.dindex.zip (1,35 MiB) ...
  Downloading file duplicati-ia566c70b25e64762a9242a95615e4135.dindex.zip (1,58 MiB) ...
  Downloading file duplicati-ia58527a0e10e445a80b1b99af33a983c.dindex.zip (1,82 MiB) ...
  Downloading file duplicati-ia5e8956661d64b78aab2cb2e7ce1369d.dindex.zip (1,32 MiB) ...
  Downloading file duplicati-ia642630dc49f455da105e022ecbf950c.dindex.zip (701,45 KiB) ...
  Downloading file duplicati-ia695eb65cf7a4311bc2ebb1e550925d1.dindex.zip (593,70 KiB) ...
  Downloading file duplicati-ia764f1ec972e4c368f8b697ef3d7b836.dindex.zip (1,27 MiB) ...
  Downloading file duplicati-ia7c0bf182c0d45d8976ee7d919ebf973.dindex.zip (1,66 MiB) ...
  Downloading file duplicati-ia874602756914c00a3b3e6af11084e71.dindex.zip (1,35 MiB) ...
  Downloading file duplicati-ia90c76a02cbc4bcaa17aced728b7248e.dindex.zip (1,29 MiB) ...
  Downloading file duplicati-iaac1862ed5db408a861f4801344a5b76.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-iaef93e1f9b8246be8efc432ccbbd708a.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-ib043222bccad489cbfee7cf9d5fe297c.dindex.zip (3,53 MiB) ...
  Downloading file duplicati-ib30473665cd1446f847c1f64d376e403.dindex.zip (12,08 MiB) ...
  Downloading file duplicati-ib41be0a84ac74401aea62f3bc9576a4a.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-ib6266b083171405cb54546bb9899e52a.dindex.zip (1,22 MiB) ...
  Downloading file duplicati-ibcec5d0a1f3547fa83803689b6e5d6dd.dindex.zip (1,43 MiB) ...
  Downloading file duplicati-ibd0cad73e37742e2a2670038b224d0c3.dindex.zip (2,85 MiB) ...
  Downloading file duplicati-ibd5e528fbe99418bac6cbf5b48bca652.dindex.zip (1,32 MiB) ...
  Downloading file duplicati-ibd627d621118450c99121f8d3a03cb89.dindex.zip (1,50 MiB) ...
  Downloading file duplicati-ibe63bdaabee24227bfcf399592ba4f11.dindex.zip (731,06 KiB) ...
  Downloading file duplicati-ibef2ba2a09fe43bdac7581b9ce2eca43.dindex.zip (641,15 KiB) ...
  Downloading file duplicati-ibf8060686ec0454a8a56cf0ac967ed19.dindex.zip (1,52 MiB) ...
  Downloading file duplicati-ic0666f426d7e4ac79b716f3eef01c97e.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-ic0c01375ef18482eba2096acc78e69e0.dindex.zip (1,42 MiB) ...
  Downloading file duplicati-ic0c0baaa89ac453ba43a930b47df3a33.dindex.zip (1,43 MiB) ...
  Downloading file duplicati-ic296905fee9a466ea9a64a7bfee3fb2a.dindex.zip (350,20 KiB) ...
  Downloading file duplicati-ic2eed4469f7a4626b8fdb40f8e85bf4b.dindex.zip (1,46 MiB) ...
  Downloading file duplicati-ic3c5821d88bf416bbba55bbe3afdfffc.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-ic4870539cf2842c9bfa34ca717bbf0a6.dindex.zip (3,40 MiB) ...
  Downloading file duplicati-ic5425949513d40a28015696c162b59a2.dindex.zip (1,63 MiB) ...
  Downloading file duplicati-ic679a2a8ea05415eb43d4cf28dcbb842.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-ic7a130a25ec242789cf80f05c11c47f0.dindex.zip (1,59 MiB) ...
  Downloading file duplicati-icb3ce56807424885945dee9dd620183c.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-icbc5ebcdfab44156ad830bb539abc215.dindex.zip (835,74 KiB) ...
  Downloading file duplicati-icbe13101d3554867aa8e7b829e6a7fcb.dindex.zip (3,01 MiB) ...
  Downloading file duplicati-icca6ea87895b4a27a8b3e09c02c77f9a.dindex.zip (1,44 MiB) ...
  Downloading file duplicati-iccd0a8b5537f44c0a5dc052125741056.dindex.zip (1,63 MiB) ...
  Downloading file duplicati-ice3dfb793750421897ee91305b625bf0.dindex.zip (1,34 MiB) ...
  Downloading file duplicati-id00b4468fc174d18b3758cab93252ab1.dindex.zip (1,61 MiB) ...
  Downloading file duplicati-id0926d3459524e4c8f2af02f9ebe617e.dindex.zip (1,64 MiB) ...
  Downloading file duplicati-id1b6574feeb54bb3b424dd2a6616f064.dindex.zip (3,64 MiB) ...
  Downloading file duplicati-id21aa45971ca43f0a777d5cf284fde5f.dindex.zip (1,52 MiB) ...
  Downloading file duplicati-id2348d57a4d54bcfa0e59e0a0114c0e9.dindex.zip (1,29 MiB) ...
  Downloading file duplicati-id4f43c083061418b9f945554d64f9c7d.dindex.zip (1,41 MiB) ...
  Downloading file duplicati-id5e980925d3e41b2beb081846118da47.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-id75f3f19b3f64027a768c93d7bd72e6f.dindex.zip (1,42 MiB) ...
  Downloading file duplicati-ida1e23a5485844fcb36edf3214823d27.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-idc01f6754d674acea0cf7aaf1d204fc6.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-idc6ca78c83f24ef5a9884d1ac60763d8.dindex.zip (1,57 MiB) ...
  Downloading file duplicati-idd6281e621474f1aa93f414e80e5c21f.dindex.zip (1,34 MiB) ...
  Downloading file duplicati-idf290c33930540d88681f6339890f0cd.dindex.zip (640,21 KiB) ...
  Downloading file duplicati-ie0e7377353744341bd8ce29f1f8c1434.dindex.zip (1,37 MiB) ...
  Downloading file duplicati-ie35bbbca670040c1acee6f93b60dcea5.dindex.zip (1,31 MiB) ...
  Downloading file duplicati-ie4b0257643054a42a1c9fd0ad2de921e.dindex.zip (2,98 MiB) ...
  Downloading file duplicati-ie552c38ccdb44bb2ad49c3b945a8529d.dindex.zip (1,34 MiB) ...
  Downloading file duplicati-ie55ad2ce7f594772a7823557548c6fd3.dindex.zip (1,57 MiB) ...
  Downloading file duplicati-ie5711361c945410c8e1a907358801d42.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-ie70de4bb87244d6aa75dc3b2a2d7f68c.dindex.zip (1,29 MiB) ...
  Downloading file duplicati-ie775d7f80b41470a944ba708ea9d40e2.dindex.zip (4,40 MiB) ...
  Downloading file duplicati-ie7a0d5d184c64298893980d8db21b2f2.dindex.zip (587,97 KiB) ...
  Downloading file duplicati-ie7e0e0cc0a644a5d8a32db7ca8cf6125.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-ie9fecde4b89d45ec8fcb13d1719f4b82.dindex.zip (2,15 MiB) ...
  Downloading file duplicati-iebc289613e2d4c08b1ad4edda8a8d7fa.dindex.zip (7,83 MiB) ...
  Downloading file duplicati-ieea0be7ec97b4d3bbb8349fc6867fd4c.dindex.zip (1,59 MiB) ...
  Downloading file duplicati-ieff67d6f29ae4971bcc16ea4d4e47a9f.dindex.zip (1,33 MiB) ...
  Downloading file duplicati-if0ee72e2a4414858ae562eb9f5815eb8.dindex.zip (457,76 KiB) ...
Remote file referenced as duplicati-b3c9ff87206cf4ba690e6d92caab74525.dblock.zip by duplicati-ieff67d6f29ae4971bcc16ea4d4e47a9f.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-if191b76fe3f54c0fbaf3311e7e7b0889.dindex.zip (611,67 KiB) ...
  Downloading file duplicati-if2567e75d0e34e3c9c77a7f1f71bdf06.dindex.zip (3,92 MiB) ...
  Downloading file duplicati-if2a655095c8947ee9d0bbe0093499a72.dindex.zip (1,50 MiB) ...
  Downloading file duplicati-if3a77854dad049598cf9b51c75fb3ed6.dindex.zip (1,30 MiB) ...
  Downloading file duplicati-if405776b24ee498b9c6c41d45332b4e5.dindex.zip (3,09 MiB) ...
  Downloading file duplicati-if5a2fdcb6403402cb79305dee1fe03cc.dindex.zip (592,52 KiB) ...
  Downloading file duplicati-if70be0f451e74f04b18034c6ea787876.dindex.zip (1,36 MiB) ...
  Downloading file duplicati-if8a80064a63c4d7194d909fdf7397c85.dindex.zip (1,66 MiB) ...
  Downloading file duplicati-if99996ee3d734441ad0ea677e785f629.dindex.zip (1,29 MiB) ...
  Downloading file duplicati-if9b8f674d84e4c75b6975f4dc7b775aa.dindex.zip (613,65 KiB) ...
  Downloading file duplicati-ifa913a012ffc481e970de2013626aa55.dindex.zip (1,45 MiB) ...
  Downloading file duplicati-ifc60d73d406c4148ac923584cab52f60.dindex.zip (731,49 KiB) ...
  Downloading file duplicati-ifc9e61633d0a48ec9c64232f91154d08.dindex.zip (719,56 KiB) ...
  Downloading file duplicati-ife461b8249974283a404df57eeafda5e.dindex.zip (1,41 MiB) ...
Remote file referenced as duplicati-b49cf398cfb4a4b9396545661f20930dc.dblock.zip by duplicati-ifc9e61633d0a48ec9c64232f91154d08.dindex.zip, but not found in list, registering a missing remote file
  Downloading file duplicati-ifef271d702054eff89213109cee300c8.dindex.zip (931,58 KiB) ...
Replaced blocks for 6 missing volumes; there are now 6 missing volumes
  Downloading file duplicati-b04dbf771375f4bbb99319791186c0510.dblock.zip (70,85 MiB) ...
  Downloading file duplicati-b0b262d9508294b5699a0b5e9471fccae.dblock.zip (14,39 MiB) ...
  Downloading file duplicati-b0ef25c23cc5f4f30bd5bb09830e99ab8.dblock.zip (5,53 MiB) ...
  Downloading file duplicati-b0f79227a1e04416ba35e399f681ce1a7.dblock.zip (206,73 MiB) ...
  Downloading file duplicati-b24f8bc0120264065b400b36ec4eedcd2.dblock.zip (5,49 MiB) ...
  Downloading file duplicati-b3aacb8ea4d9b448581ab928e788c6f30.dblock.zip (22,31 MiB) ...
  Downloading file duplicati-b417d6d34793a461e98f85b8263357a06.dblock.zip (70,67 MiB) ...
  Downloading file duplicati-b48a3689f53914157a5f6f2d8f4a5b55f.dblock.zip (5,87 MiB) ...
  Downloading file duplicati-b4f243658965c4e4182dd200ec8e005cd.dblock.zip (30,29 MiB) ...
  Downloading file duplicati-b4f525ba820104a29b8d3ab7fe241977f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b50d82efe924444149ab69e01a1649da9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b563899b73cef4e19981053c121831031.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b57085a9ca06d4ca6bc3eb8833cc76ea4.dblock.zip (1,63 GiB) ...
  Downloading file duplicati-b5ce623286d434a7abecaf682ac1196d5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b5eeb6de15d41423cad3aadb7c49caed1.dblock.zip (615,03 MiB) ...
  Downloading file duplicati-b606add34ede043d9a71778820cdb9d46.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b60e540cce8984e828b1e2c35d3153691.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b6762ddcb406d459e917cd04459633fac.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b6afc40459d7047e7aa4fb48ba5dd5256.dblock.zip (1,94 GiB) ...
  Downloading file duplicati-b6b35c01636d242a3a25f30f50b3852b7.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b71f8e26d1069406891e3e41751c5720d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b7366e52f5418438286b5fd12abf7904b.dblock.zip (461,85 MiB) ...
  Downloading file duplicati-b7b1f328a7d284922b3a89697d500f409.dblock.zip (1,32 GiB) ...
  Downloading file duplicati-b8023810d93b74aa7860542e51bce3d30.dblock.zip (5,08 MiB) ...
  Downloading file duplicati-b80e87f0422f848e3b192298e99288cb8.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b820d802308214322973110e0c8c5c635.dblock.zip (928,92 MiB) ...
  Downloading file duplicati-b8329e236765f4656ac9d30904da3d36c.dblock.zip (754,32 MiB) ...
  Downloading file duplicati-b845820c1110a4c04a843e3af3ef4f2d2.dblock.zip (1,08 GiB) ...
  Downloading file duplicati-b8766af1d0e0d4188b4bd72ffc4be76c1.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b8f97217e17374acf8d4eacd55daf3855.dblock.zip (648,17 MiB) ...
  Downloading file duplicati-b935c8e78284c44b79dbf6f92344a4ec9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b951cb8404d0e4872ba87e39e92fd49f2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b9683421eae5d45b8b1176e4c694219da.dblock.zip (1,12 GiB) ...
  Downloading file duplicati-b97eb52e95ae649f49a86a27c93370347.dblock.zip (1,94 GiB) ...
  Downloading file duplicati-b993c12244e4e4775b4d5100d9b299b0e.dblock.zip (130,43 MiB) ...
  Downloading file duplicati-b9b58e1e93a514dcd9a39358017d31373.dblock.zip (424,47 MiB) ...
  Downloading file duplicati-b9ecab821ca9a44d3b61d2f1fd33f480a.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba28a220b87814722bf777cee5536ed75.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba6c76d55dfd547e6a5af5404693a9bc8.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba71c957a6bf54fd9bb9c0bb111b72499.dblock.zip (545,21 MiB) ...
  Downloading file duplicati-ba8842231a36948fba89c5850044c4d41.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba9d44c989e674c71a530713960339f7f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bac2f8b91b5fd40a49b3afb66d8e0a54b.dblock.zip (1,66 GiB) ...
  Downloading file duplicati-bac75d3b4ed114a66ab9dbea6731cb57f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb1b51d3d1b86466ba3dd123904c28386.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb2fd77576725445ca17e2e4cb141c588.dblock.zip (1,59 GiB) ...
  Downloading file duplicati-bb4d6bd6e73d74d27873d4255bc04052c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb6f4cb7f3ccb402988be3f166f4e8e8a.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb7a558821b0b476a982a31b9d14af6e5.dblock.zip (13,76 MiB) ...
  Downloading file duplicati-bb80e236fd4694e6fb36d18b9cf2e7970.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb9e5497ddc034df7a272492b4bb55b0b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bbafb50bbfd1c416c983d913f43169f79.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bbc5f617068af4a4a80cd2c0c27f853d2.dblock.zip (1,35 GiB) ...
  Downloading file duplicati-bbc63295d9d264b1a8830ba7d7cef6cf3.dblock.zip (921,59 MiB) ...
  Downloading file duplicati-bbd15cf43fc6a470fac836515610d507e.dblock.zip (1,49 GiB) ...
  Downloading file duplicati-bbf57a2e55d0549438c71f58e2212f2fb.dblock.zip (1,56 GiB) ...
  Downloading file duplicati-bc06231cbd8f2430abebf6b26f26916e5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc12d9ed525a744f8ab2d636b2075cfc9.dblock.zip (1,41 GiB) ...
  Downloading file duplicati-bc41d92e4ac2945bab1117afe6e3f0c66.dblock.zip (421,14 MiB) ...
  Downloading file duplicati-bc480a3f6ab794f74b172ecd7bea201b6.dblock.zip (709,89 MiB) ...
  Downloading file duplicati-bc4b964beb9ab4af8bc4a0a8cc61025d4.dblock.zip (574,71 MiB) ...
  Downloading file duplicati-bc5be58ba1a4a4beb9087fb0a2772eed0.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc7a8fbcc2e834343b392a9a6236133fb.dblock.zip (1,21 GiB) ...
  Downloading file duplicati-bc7c34a5dce264f69b4cf8258c84628cd.dblock.zip (1,82 GiB) ...
  Downloading file duplicati-bc93bbf85cf964afaadfcfb2b866dae64.dblock.zip (15,70 MiB) ...
  Downloading file duplicati-bcbb320814fd4460185913f29a93f1861.dblock.zip (1,47 GiB) ...
  Downloading file duplicati-bcc471b671c514f9d9c34ae500cb7663e.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bcc70e176f61a476e854552b1215922f9.dblock.zip (5,55 MiB) ...
  Downloading file duplicati-bcf99907797084eeeb1319f55b61a22c6.dblock.zip (1,12 GiB) ...
  Downloading file duplicati-bcfc1186914d04a90b6342923f343b88b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bd7e61aa94e1241ce95bedf032b94c0c5.dblock.zip (1,63 GiB) ...
  Downloading file duplicati-bd908dab90d6243a49fe7fe671bbc83f7.dblock.zip (417,40 MiB) ...
  Downloading file duplicati-be15b3ab9487546f49e030b78efd539d3.dblock.zip (1,98 GiB) ...
  Downloading file duplicati-be3f1699391a7445b859c57296c2de67c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be46de87879834f3595c5bd546d0a8e37.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be4c388b8cc4440cbba96751623283124.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be5e640f17937457d9352032769adf911.dblock.zip (1,37 GiB) ...
  Downloading file duplicati-be74a4bdd1aff4ee2b3d7e4e9bbd5be84.dblock.zip (1,54 GiB) ...
  Downloading file duplicati-be87f5f73b63c48b3a0db64eff888f206.dblock.zip (99,20 MiB) ...
  Downloading file duplicati-be8f67824d79f4dae8f13cf87b2451bb8.dblock.zip (1,96 GiB) ...
  Downloading file duplicati-beb27d4385f6d466582b8df5f97c58375.dblock.zip (2,00 GiB) ...
Failed to create built-in ZIP archive, falling back to SharpCompress => Number of entries expected in End Of Central Directory does not correspond to number of entries in Central Directory.
  Downloading file duplicati-beb75b6e3d34045c3b8176e5bf8470497.dblock.zip (601,33 MiB) ...
  Downloading file duplicati-befc2d8e958d646d59adba853f22fa4a5.dblock.zip (423,60 MiB) ...
  Downloading file duplicati-bf0939a4278cc48da988cf59bec5f298d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bf46ef98e17bd49d39f30fac04963b400.dblock.zip (1,93 GiB) ...
  Downloading file duplicati-bf9659dfe19eb4be6b46fc1e3536fdbcd.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bfb3abb7a03d44236a5cab248ca553407.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bfd48e1c0bc014c28aa9e3bf1d683105f.dblock.zip (1,18 GiB) ...
  Downloading file duplicati-bfd4ae147ade34cd0b8712c9c806ad2d2.dblock.zip (60,56 MiB) ...
  Downloading file duplicati-bffc1a3a3552942a1a6c7a92fb754462d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0015ef03cc6a455aaff36dacb75f78c2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b02298eb34c2746df9842ec4fe56d178e.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b05a98506b8824a839c1dbd3dc5a5cfa2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b08d17664ccc14f7bab9042774d2ee31d.dblock.zip (415,96 MiB) ...
  Downloading file duplicati-b09d3045f5e394158b74a4a4a41bd8a2b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0a4674c58a204db39fe9eb163bcd3a6c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0b136ca31d6c4d2ca2eb98b2ae166779.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0b8db8346b324715bb4b19c7dd15400f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0c75f63269d347d083e80bd7de1f7df5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0cc8666cea174aeb9b3529de7155c654.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0cc8bca1fe36472797ede215aac308fb.dblock.zip (757,47 MiB) ...
  Downloading file duplicati-b0d106f2c2dfc4b5e8d78e2ba869039d9.dblock.zip (476,18 MiB) ...
  Downloading file duplicati-b0d36203cf117460b98353d8a44c5fe31.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b0dfbe11f25dd46d0b04794984523f1ac.dblock.zip (1,60 GiB) ...
  Downloading file duplicati-b100be4c2c4c94a65bda541e44ee66cb5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b115754ed047946f0af52fe972be03d0a.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b12810d28f27a4c2b8ef168b5f4e7de09.dblock.zip (1,96 GiB) ...
  Downloading file duplicati-b1284e31d1ce24854a3649b40f058cf23.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b1349fb6adb114922b96d93c061a213f8.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b137139ad9fdb45c09686d74b65cbe447.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b140600cabd804c1b8a639b1dec4f01bb.dblock.zip (2,00 GiB) ...
Unexpected changes caused by block duplicati-b137139ad9fdb45c09686d74b65cbe447.dblock.zip
  Downloading file duplicati-b157f394ab603410b9536b3da462fb164.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b164bc4937d9a4dbe974d964284148f01.dblock.zip (1,75 GiB) ...
Unexpected changes caused by block duplicati-b157f394ab603410b9536b3da462fb164.dblock.zip
  Downloading file duplicati-b176ead6964274821bc8a491b80eafadd.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b176ff88374da489594db8bc65f1980b2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b1812a1e3b8ad432083a0a037dad308b5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b1a9f9e784b9445669a36baeb69d1eb4e.dblock.zip (36,59 MiB) ...
  Downloading file duplicati-b1b33b3a437d04418976698cb304b89b8.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b1b37ed8975444caa916933275249afea.dblock.zip (5,64 MiB) ...
  Downloading file duplicati-b1b6323fcfc044612849c7dcc0c4e2c51.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b1e9277a900a84bd18ab84d50289bb66b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b2252bd1714e1406e95ae4c013ac08074.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b237219b0ee154d2ebf608dfe15ca3283.dblock.zip (1,14 GiB) ...
  Downloading file duplicati-b259c3e4c251646048f924892bfce6b59.dblock.zip (2,00 GiB) ...
Unexpected changes caused by block duplicati-b237219b0ee154d2ebf608dfe15ca3283.dblock.zip
  Downloading file duplicati-b2745554f30194aa59610f74290df0923.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b284fbc3ae082480fac93214dfcefc166.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b2c97c469a2454904b8908a1ccd58a097.dblock.zip (31,15 MiB) ...
  Downloading file duplicati-b2d7d6fde783747af86dcc21f9c5ccba2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b2d8cbb6dc43b418cbb3c6ef5f6e9ab8d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b2deeaada2669411f8cd8bb8fedbd64c5.dblock.zip (895,31 MiB) ...
  Downloading file duplicati-b2f5ab071424741fc84fa24a680becec5.dblock.zip (1,87 GiB) ...
  Downloading file duplicati-b30a435b8d5b7491294c12dee788a6e57.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b30fff4ebb0994b35b3fa5a113828c7e9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b31e5d466873e4e9eab1904634609c765.dblock.zip (485,43 MiB) ...
  Downloading file duplicati-b32087decd5f14747ab1bc0dfdccb729c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b335b2627f25f43ffa2f95a8d5a6b8420.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b33a62b4516554f5f901eee03c701d9fb.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b34aea1e77cdf493fbaad0326adbfd446.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b35387009ed9d48548aa567f176fe9216.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b35703de9e90544f58cf201a117a3ed8b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b36b77056925a458abd48b4e61e29e65e.dblock.zip (1,75 GiB) ...
Unexpected changes caused by block duplicati-b35703de9e90544f58cf201a117a3ed8b.dblock.zip
  Downloading file duplicati-b392b57e31e4c42d79050bdca30cf0bb3.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b3b1afdc4506d42e5aa1abc01d332877e.dblock.zip (1,29 GiB) ...
  Downloading file duplicati-b3d7f3d42cee144509f565d74b532b904.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b3dabeca956dd46cc9927eaee2bb3c4f6.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b3e24810aeabe4446850d4e379cd5a982.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b3fdf1684628441a5b37e461170cfce86.dblock.zip (531,54 MiB) ...
  Downloading file duplicati-b4187729aba7742be89012f61e1bf6446.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b447c5c5665204933af0fe3692176e1e6.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b44bfa50b23f847ab9f472326408b08a5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4565349507e8498c9c2d0d977cf5c849.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b477dd79f8bd242ec9e4a010e30286774.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b49b3ad2983d443cebf748a4a72266136.dblock.zip (1,79 GiB) ...
Unexpected changes caused by block duplicati-b477dd79f8bd242ec9e4a010e30286774.dblock.zip
  Downloading file duplicati-b4a51291c229848c1b1e05bf679dcfdbc.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4a826318e58d4ccea508479708dd4f8c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4b08525a31a44380ab4ec028a5bbadd4.dblock.zip (5,56 MiB) ...
  Downloading file duplicati-b4b3ee5ffd6584f1285f428bf456f69f2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4debc6aa33c74019b5fff9cd2a1a97f6.dblock.zip (1,54 GiB) ...
  Downloading file duplicati-b4e6a956d566f4c04aa4547470119bea9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4e6a9f1b49b24fc0abb2f991e49bae0b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b4f5001c9c68549d99307c55057fc8c0f.dblock.zip (567,56 MiB) ...
  Downloading file duplicati-b506ee6616696406faa53ca14129beb94.dblock.zip (2,00 GiB) ...
Unexpected changes caused by block duplicati-b4f5001c9c68549d99307c55057fc8c0f.dblock.zip
  Downloading file duplicati-b50d63d32c13142e8abdb4cac40ec8ea7.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b534e3a78a9bc4e89ba91ea38d1ea21d7.dblock.zip (69,85 MiB) ...
  Downloading file duplicati-b58e94ca540d048aea74793d77da32bb7.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b58fa1b92b7c94a0c90795160e3aab8c9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b592a31b88552458dbbc28116754e5605.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b5a92273fe63440ec957fd91bb5c25a92.dblock.zip (5,11 MiB) ...
  Downloading file duplicati-b5cef44e12933467f8a11165d3324ef31.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b6317f12ebed54a4cb10406f9fe404786.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b63a5a3946a3448aa9af86224766abf1d.dblock.zip (25,10 MiB) ...
  Downloading file duplicati-b63fcf5e0546a4ac2aeca5aac6e3aa74b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b64cf60aa2bcb4ce2acf0335338404d63.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b66aee2d348bf435086d2f457c18e2ee0.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b6d1300785b344d3cb2ee7c9edee9b22d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b7051f745103342aba2ad599c8e2b28a8.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b71ea12949ea34efa8432477897c439b7.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b738aeae0135c458a9c57ceede35d0eec.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b74613c12694e42a0b90ed271686a6a75.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b7f77e97e4ce442a3809b32621577e28d.dblock.zip (5,67 MiB) ...
  Downloading file duplicati-b80b2b88039934cb6b713d56e297ded09.dblock.zip (108,06 MiB) ...
  Downloading file duplicati-b8117191adebf4ea5b25a703ad819cd59.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b82a9e3d9f57043dbb5ba5e07d61c9b3b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b83aa42bd7f254b8baea83d200f219e25.dblock.zip (58,36 MiB) ...
  Downloading file duplicati-b83ea880acaf5425ca77782a01eea8981.dblock.zip (23,84 MiB) ...
  Downloading file duplicati-b854d2285062a4515bca9f5b11ff42bdb.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b861523cf13084b17991b92d2a6d35b7c.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b87d4929ac07d4d009e79479e1bc2072d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b89736ab3ec264e688b8039a04077294f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b8a6c73396c9646409a85fc3e07a52f18.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b8af2968e72e94614bb45c6f1cc56849b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b8f49c89e55d3481880adf8260593d488.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b8f80fcb9b0814cf899994614ea0b5ed5.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b9350d90cbdd648a9b77ac7c1ef73bada.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b956d3dcf8b0446f98e9eec37b4244fe6.dblock.zip (436,89 MiB) ...
  Downloading file duplicati-b9bfe0d93ea004a2e97631493ad5a3f8d.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-b9d186a00a29641dd879209ccab766038.dblock.zip (21,50 MiB) ...
  Downloading file duplicati-ba0ec800f66a141e2b0caba79c6ea92ab.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba68118208953466b9bb3419fcd867ca3.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba69ed9b706fb43a6a3ba75e07bb6ec80.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-ba6f79e8b919846dd9ceb56732ced211f.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bae45d71a19944d36900db3e5cdb19a0e.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb4cab08e5fd14cd6afa7d74150d6513e.dblock.zip (1,70 GiB) ...
  Downloading file duplicati-bb5ab368dc39b474995f7ce5713d6ffc2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb6a3a68fc3274cb9aff40c700e0a4338.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bb9d4c3497c464ebb914498adeb570194.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bba194741c18c4c288c1f1f3602bb708b.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bbd05f15799c0485380942fb946e672ea.dblock.zip (35,75 MiB) ...
  Downloading file duplicati-bbd17a6415e304e2783554941ae54842a.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bbe25625adde44a2b9f06c8f07a707b69.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bbf3e4d014e4947c5a271dc926abdf9f8.dblock.zip (5,88 MiB) ...
  Downloading file duplicati-bc00174120aa14a9d8a7867815ef437de.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc07fd4c8130a4855abc0d02bfbc0498f.dblock.zip (813,11 MiB) ...
  Downloading file duplicati-bc0f27841e8c34d33986077b42a76c6b0.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc3b99f8abc7b419e97bfe2903fd511e2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc46714a611a84de48af53bbbd4d01019.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc6239e109b2b45cb9684bd03867c70e1.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc6d6c3faca5746399692014b97efcd28.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc96b129a3fc9434183bc81a7e24598d0.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bc9e39b389ef04a74962e321fcdc2a9e9.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bcae07d91b3a7493f97cbc3224534f6e2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bcbcea36ec8a44764aa2a4d64586de949.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bcbda64b038034702aab1c12fb980931a.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bcf18bf3301fe4212b263db5a424ffae3.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bd0d318daa27040af8c892faa37e67794.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bd2822e9b11c0452a9b7436356910b101.dblock.zip (1,15 GiB) ...
  Downloading file duplicati-bd2cdff5dd9464affbbdbfa886fd3ab24.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bd3b4c246051d4e90ab5471307d9b76b3.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bd61b5e8f80a84669aa46ca9eb7e82815.dblock.zip (913,55 MiB) ...
  Downloading file duplicati-bd9075448c6514b2d863a0e546d5c330f.dblock.zip (1,72 GiB) ...
Unexpected changes caused by block duplicati-bd61b5e8f80a84669aa46ca9eb7e82815.dblock.zip
  Downloading file duplicati-bdb1d2aca1f7142b38a66006fa7c0dd1e.dblock.zip (2,00 GiB) ...
Unexpected changes caused by block duplicati-bd9075448c6514b2d863a0e546d5c330f.dblock.zip
  Downloading file duplicati-bdf5be6c540c140e381aa3f4bc4f18f99.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be154caf0e6ba45f498117fd3fc9daadb.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be3b8dd95b5b64891bc42c1285a21ae36.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-be4dec922e6fc4357b990ce9d6bb01f52.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bee5907202c144c9f836aec192cdd2146.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-beeb67e6239b440119f277eeee07219ac.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bf10e8563f07e418393665bfbfdb04465.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bf320748b80e447dd870c8a4e732500cb.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bf3dd71df1362435aaa664248cd4d8fad.dblock.zip (564,48 MiB) ...
  Downloading file duplicati-bf6d1ce280e80486b96ebd9b7a8a8e3d2.dblock.zip (2,00 GiB) ...
  Downloading file duplicati-bfcb21395de3542d0bf4998f002982ad5.dblock.zip (48,28 MiB) ...
  Downloading file duplicati-b159818b633b24f32bcfa362fea7132a8.dblock.zip (2,00 GiB) ...
Notes: I modified the log to edit the location of the backup so anonimize the path a little bit. I don’t think that’s relevant, but I point it out just in case.
Could please anyone help me troubleshoot this so I can recover this old backup?
Nothing in the Disaster Recovery Guide helps because most of it needs a working database.
I am willing to accept some data loss, but I can’t purge or clear the backup without a Database (or can I?).
Thak you for your assistance.
