Hello,
In one specific computer, the backup never ends.
The backup always stuck in “Verifying backend data” or “Waiting for upload”
I tried to rebuild database and it stuck in "Backend event: List Started: ()
18 de Out de 2021 às 10:07: Backend event: List - Started: ()
18 de Out de 2021 às 10:07: Starting - RemoteOperationList
18 de Out de 2021 às 10:07: ExecuteNonQuery: INSERT INTO “Configuration” (“Key”, “Value”) VALUES (“repair-in-progress”, “true”) took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: INSERT INTO “Configuration” (“Key”, “Value”) VALUES (“repair-in-progress”, “true”)
18 de Out de 2021 às 10:07: ExecuteNonQuery: DELETE FROM “Configuration” took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: DELETE FROM “Configuration”
18 de Out de 2021 às 10:07: ExecuteReader: SELECT “Key”, “Value” FROM “Configuration” took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteReader: SELECT “Key”, “Value” FROM “Configuration”
18 de Out de 2021 às 10:07: ExecuteNonQuery: CREATE UNIQUE INDEX “Index_Block_TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” ON “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“BlockHash”, “BlockSize”); took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: CREATE UNIQUE INDEX “Index_Block_TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” ON “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“BlockHash”, “BlockSize”);
18 de Out de 2021 às 10:07: ExecuteNonQuery: CREATE UNIQUE INDEX “Index_File_TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” ON “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“FileHash”, “BlockSize”); took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: CREATE UNIQUE INDEX “Index_File_TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” ON “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“FileHash”, “BlockSize”);
18 de Out de 2021 às 10:07: ExecuteNonQuery: CREATE TEMPORARY TABLE “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“FileHash” TEXT NOT NULL, “BlockHash” TEXT NOT NULL, “BlockSize” INTEGER NOT NULL) took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: CREATE TEMPORARY TABLE “TempSmalllist-0AE9975254CF9747BCE40D23F1F5598C” (“FileHash” TEXT NOT NULL, “BlockHash” TEXT NOT NULL, “BlockSize” INTEGER NOT NULL)
18 de Out de 2021 às 10:07: ExecuteNonQuery: CREATE INDEX “Index_TempBlocklist-97B86CEBFB570843807E7B19758F99D6” ON “TempBlocklist-97B86CEBFB570843807E7B19758F99D6” (“BlockListHash”); took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: CREATE INDEX “Index_TempBlocklist-97B86CEBFB570843807E7B19758F99D6” ON “TempBlocklist-97B86CEBFB570843807E7B19758F99D6” (“BlockListHash”);
18 de Out de 2021 às 10:07: ExecuteNonQuery: CREATE TEMPORARY TABLE “TempBlocklist-97B86CEBFB570843807E7B19758F99D6” (“BlockListHash” TEXT NOT NULL, “BlockHash” TEXT NOT NULL, “Index” INTEGER NOT NULL) took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: CREATE TEMPORARY TABLE “TempBlocklist-97B86CEBFB570843807E7B19758F99D6” (“BlockListHash” TEXT NOT NULL, “BlockHash” TEXT NOT NULL, “Index” INTEGER NOT NULL)
18 de Out de 2021 às 10:07: ExecuteScalarInt64: INSERT INTO “Operation” (“Description”, “Timestamp”) VALUES (“Recreate”, 1634562462); SELECT last_insert_rowid(); took 0:00:00:00.002
18 de Out de 2021 às 10:07: Starting - ExecuteScalarInt64: INSERT INTO “Operation” (“Description”, “Timestamp”) VALUES (“Recreate”, 1634562462); SELECT last_insert_rowid();
18 de Out de 2021 às 10:07: Starting - Recreate database for repair
18 de Out de 2021 às 10:07: Starting - Running Repair
18 de Out de 2021 às 10:07: A operação Repair foi iniciada
18 de Out de 2021 às 10:07: A operação Repair falhou com erro: No filelists found on the remote destination
18 de Out de 2021 às 10:07: Running Repair took 0:00:00:06.160
18 de Out de 2021 às 10:07: Recreate database for repair took 0:00:00:06.158
18 de Out de 2021 às 10:07: ExecuteNonQuery: PRAGMA optimize took 0:00:00:00.000
18 de Out de 2021 às 10:07: Starting - ExecuteNonQuery: PRAGMA optimize
18 de Out de 2021 às 10:07: RemoteOperationList took 0:00:00:05.970
18 de Out de 2021 às 10:07: Backend event: List - Completed: (935 bytes)
