It’s a bit more subtle, but I think that’s usually the case. The general idea is it’s a home directory, which means ~/ is meaningless unless user asking is said. You can also say user after the tilde:
Tilde Expansion on the bash man page details how it works.
So if you’re user root (via sudo or otherwise), ~ means one thing. Running as you, it’s another.
Duplicati, like many programs, stores data based on home directory, so the user used matters. Changing the user to a different one may get you a different home directory config + surprises.
Thanks for this helpful lesson!
I only knew that ~ is my home dir. But that was only half the truth.
So as long as I run Duplicati as a service as root, the database is located in a ~root/ or /root/ subfolder.
If I run Duplicati manually as a user, the database will be in the user’s ~/ or /home/<user>/ subfolder.
Hopefully I’ll remember this until the next installation, when I might miss the database again
Thank you for your great support!
BTW: As for the service options, I found the explanation why I used them:
Following the installation guide from Installation - Duplicati 2 User's Manual, I copied the whole line DAEMON_OPTS="--webservice-interface=any --webservice-port=8200 --portable-mode" from the example.
@kenkendk You asked what could have been done better.
In the user’s manual linked above
Edit the file /etc/default/duplicati and add DAEMON_OPTS options to your liking: sudo nano /etc/default/duplicati
the example
# Additional options that are passed to the Daemon.
should be declared more clearly as just an example instead of a template.
And the word(s) (DAEMON_OPTS) options could be provided with a hyperlink that leads to the descriptions of the options at Other Command Line Utilities - Duplicati 2 User's Manual And there should again be a note under --webservice-interface that the value any can be a security risk and is not normally required.
