I’m trying to backup to AWS. I have everything setup, but when I go to run the backup it says
One or more errors occurred. (Connection reset by peer (Connection reset by peer) (One or more errors occurred. (Connection reset by peer)))
Hello
It looks like a network problem. Did you verify the server address ? check SSL ? Maybe provide a screenshot ?
I selected SSL, and changed to the default region, instead of us-east-2, and it works now
