I’m trying to add some source exclusions to a backup based on a string within a filename, but the filter the GUI is generating fails the backup. This is what I did:
Add filter
Set “Exclude files whose names contain”
Entered my string “GMWNCWSLYA”
Add a second exclude filter with string “lock_v2”
Saved the backup
When I run the backup I get:
System.ArgumentException: parsing ".*GMWNCWSLYA.*[^\]" - Unterminated [] set.
at System.Text.RegularExpressions.RegexParser.ScanCharClass(Boolean caseInsensitive, Boolean scanOnly)
at System.Text.RegularExpressions.RegexParser.CountCaptures()
at System.Text.RegularExpressions.RegexParser.Parse(String re, RegexOptions op)
at System.Text.RegularExpressions.Regex..ctor(String pattern, RegexOptions options, TimeSpan matchTimeout, Boolean useCache)
at System.Text.RegularExpressions.Regex..ctor(String pattern, RegexOptions options)
at Duplicati.Library.Utility.FilterExpression.FilterEntry..ctor(String filter)
at Duplicati.Library.Utility.FilterExpression.<>c.<.ctor>b__11_0(String n)
at System.Linq.Enumerable.WhereSelectArrayIterator`2.MoveNext()
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at Duplicati.Library.Utility.FilterExpression.Compact(IEnumerable`1 items)
at Duplicati.Library.Utility.FilterExpression..ctor(IEnumerable`1 filter, Boolean result)
at Duplicati.Server.Runner.<>c.<ApplyFilter>b__18_2(<>f__AnonymousType2`2 <>h__TransparentIdentifier0)
at System.Linq.Enumerable.Aggregate[TSource](IEnumerable`1 source, Func`3 func)
at Duplicati.Server.Runner.ApplyFilter(IBackup backup, IFilter filter)
When I edit the backup job and check the filter as text, it has been generated by the GUI as follows:
-[.*GMWNCWSLYA.*[^\]]
-[.*lock_v2.*[^\]]
Any idea why the GUI is generating a bad filter parameter?
I’m running 2.0.4.22_canary_2019-06-30 and this is on Windows.
Yeah this is an invalid regex, and it doesn’t even make sense. The caret symbol indicates start of line, but it’s put near the end of the pattern.
The reason it’s “unterminated” is because the brackets are not balanced. There is a backslash in front of one of the brackets which instructs it to be treated as a literal character match and not a regex closing bracket.
What happens if you view the filters as text, delete the [^\] part, and then save changes? Do backups work after that, or is [^\] put back in automatically again?
You’re right, I totally forgot about that usage inside bracketed character sets.
Maybe the intent was to ensure the pattern appeared in the filename portion, and to make sure no more path separators appeared after the pattern. In that case they just forgot to escape the backslash: [^\\] But even that doesn’t achieve the correct result.
Edit: I think if they prepended the entered pattern with .* and appended [^\\]* (instead of .*[^\] it would work - if the intent was to ensure it is in the filename portion
Keep in mind that if you want the pattern to ONLY match filenames and not also directories, you’ll need to adjust it slightly from my screen shot example.
Replacing the .* at the end with [^\\]* should work (if you are using Windows).
Would either of you care to see if a Duplicati issue has been filed? I used to drop diagnostic hints in the forum, but they didn’t seem to get picked up. I don’t know if an issue will move any faster, but at least it’ll be tracked…
