I was running a new backup with Google Teams and after hours it stops and give the error “Detected non-empty blocksets with no associated blocks!”
I’m running Duplicati - 2.0.5.1_beta_2020-01-18 on a FreeNAS 11.3U5 jail. In the past I had trouble getting things to work so I deleted the database and removed all the files from the Google Teams and the backup started to work.
I’ve review all the similar topics but have not found the answer. I’m not able to edit database manually.
at Duplicati.Library.Main.Database.LocalDatabase.VerifyConsistency (System.Int64 blocksize, System.Int64 hashsize, System.Boolean verifyfilelists, System.Data.IDbTransaction transaction) [0x0017d] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Backup.BackupDatabase+<>c__DisplayClass34_0.<VerifyConsistencyAsync>b__0 () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<>c__DisplayClass3_0.<RunOnMain>b__0 () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<DoRunOnMain>d__2`1[T].MoveNext () [0x000b0] in <8f1de655bd1240739a78684d845cecc8>:0
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <0e06830de9a44394a7e366951eabca52>:0
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <0e06830de9a44394a7e366951eabca52>:0
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <0e06830de9a44394a7e366951eabca52>:0
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <0e06830de9a44394a7e366951eabca52>:0
at System.Runtime.CompilerServices.TaskAwaiter.GetResult () [0x00000] in <0e06830de9a44394a7e366951eabca52>:0
at Duplicati.Library.Main.Operation.BackupHandler+<RunAsync>d__20.MoveNext () [0x01033] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Server.Runner.Run (Duplicati.Server.Runner+IRunnerData data, System.Boolean fromQueue) [0x00349] in <c5f097a49c0a4f1fb0f93cf3f5f218b1>:0 ```
