Tray icon status not updating
Duplicati 2.1.0.112_canary_2025-03-26 on Pop!_OS 22.04.
Tray icon does not change from Red X to Black normal after manually running backup job. Is this the expected behaviour? Will it only turn back to Black after regular scheduled run?
Yes and no. Up until one of the recent canaries, the logic was to keep warnings and errors until the user clicked “dismiss” on them. However, we recently changed that so the status will be cleared after each run, meaning that the icon will now reflect the last backup run.
The downside to this is that it may be possible to miss warnings, but the logic is that if they are transient, there is no value in keeping the highly visible. You can still view the logs if you want to examine the backup history.
If you use the latest canary or experimental, the icon will change as you expect.
