I no longer see the status of the Travis builds in GitHub. For example
However, Travis is still running the builds. Somehow, the results are not being communicated to GitHub anymore
I’m not sure what’s causing this. Perhaps it’s related to
I was having the same problem with my repository and Travis. Following the instructions here fixed the issue.
After this, the Travis build status started to appear again. @kenkendk, can you try the above for the main Duplicati repository?
Actually, it looks like it might be magically working again. Not sure what changed.
