I’m not a software engineer, so please bear with me, if I’m not clear.
Windows 10 64bit
Suddently Duplicated stopped performing local backup with the following error:
Unexpected difference in fileset version 169: 11/04/2019 17:47:44 (database id: 47), found 7059 entries, but expected 7174
I tried repairing DB, but I got:
Duplicati.Library.Interface.UserInformationException: The database was attempted repaired, but the repair did not complete. This database may be incomplete and the backup process cannot continue. You may delete the local database and attempt to repair it again.
in Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
Then I deleted DB e started a repair and it took forever (after 4 days it was still processing)
Then I stopped the repair, and tried to install canary.
No result. Duplicati is now unable to start. No error messages. Just nothing. I click on it in the windows start menu, and nothing happens.
I solved a similar issue by running a delete command (from the guy, advanced > commandline > choose “delete” as command and input “–version=169” as commandline arguments > “run delete command now”). Then wait hopefully.
Yes, version delete is the usual thing to try for “Unexpected difference in fileset”. It sometimes works. Problem here may be the database total deletion. I don’t know if there’s a backup copy to do that on.
