Since I said I’m trying to throttle at the router, I’m pretty sure that one was B2.
Today I have a B2 backup in progress with router throttle. Profiling log shows:
2025-07-19 07:31:40 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()
2025-07-19 07:31:43 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (716 bytes)
2025-07-19 07:35:51 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bcabe5c2e4ec04f4e936e70988a88c1db.dblock.zip.aes (9.94 MiB)
2025-07-19 07:35:51 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bae1dbf3953de426b80a0f51f7cead2b0.dblock.zip.aes (9.92 MiB)
2025-07-19 07:36:01 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bbef237781f9644db9005043a79d34063.dblock.zip.aes (9.94 MiB)
2025-07-19 07:36:01 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b0ed9c56a74ba4f8184e157ee6f812ff5.dblock.zip.aes (9.94 MiB)
ngax shows:
"OverallProgress":0,"ProcessedFileCount":5336,"ProcessedFileSize":7676826543,"TotalFileCount":7008,"TotalFileSize":8342794032,"StillCounting":false,"ActiveTransfers":[
{"BackendAction":"Put","BackendPath":"duplicati-bcabe5c2e4ec04f4e936e70988a88c1db.dblock.zip.aes","BackendFileSize":10427261,"BackendFileProgress":10427261,"BackendSpeed":-1,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-bae1dbf3953de426b80a0f51f7cead2b0.dblock.zip.aes","BackendFileSize":10398813,"BackendFileProgress":10398813,"BackendSpeed":-1,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-bbef237781f9644db9005043a79d34063.dblock.zip.aes","BackendFileSize":10426269,"BackendFileProgress":10426269,"BackendSpeed":-1,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-b0ed9c56a74ba4f8184e157ee6f812ff5.dblock.zip.aes","BackendFileSize":10424461,"BackendFileProgress":10424461,"BackendSpeed":-1,"BackendIsBlocking":true}]}
ngax shows this later on, after some uploads completed:
{"BackendAction":"Put","BackendPath":"duplicati-b58f09e3432b94295a6e318d13d8e18c1.dblock.zip.aes","BackendFileSize":10395693,"BackendFileProgress":10395693,"BackendSpeed":3465231,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-b1a9c229cb0934e0bae81aa3a7b04436f.dblock.zip.aes","BackendFileSize":10415853,"BackendFileProgress":10415853,"BackendSpeed":-1,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-b47d4b4fafefa4baab61bd5394cb1f323.dblock.zip.aes","BackendFileSize":10448621,"BackendFileProgress":10448621,"BackendSpeed":-1,"BackendIsBlocking":true},
{"BackendAction":"Put","BackendPath":"duplicati-b9c52eb988aed4b099f6087562626425f.dblock.zip.aes","BackendFileSize":10435965,"BackendFileProgress":10435965,"BackendSpeed":-1,"BackendIsBlocking":true}]}
ngax is reporting 3.30 MB/s, ngclient 3.47 MB/s. Router upload speed set to “800 Kbps”.
One difference in this test is I’m using default 4 parallel uploads. Before I used 1, trying to start with a simpler scenario, however it wasn’t having much luck ever showing the speed.
With parallel uploads, it’s doing a little better, but still seems to show the “instant-complete” BackendFileProgress, only one of the transfers has speed, and it seems suspiciously high.
I do have Wireshark running if you need that, but above report is based on just the web UI.
Although I’m not using file backend now, I started there awhile ago, then wondered if using throttle-upload was intended to register as a slow destination. It may depend on where the throttle is done. It sounds like it’s now at the backend side. I’m not sure that was always so.
I looked at websocket packets for the fourth upload, and got progress jump in 1.2 seconds.
Jul 19, 2025 07:36:10.043673000
{"BackendAction":"Put","BackendPath":"duplicati-bcabe5c2e4ec04f4e936e70988a88c1db.dblock.zip.aes","BackendFileSize":10427261,"BackendFileProgress":10427261,"BackendSpeed":-1,"BackendIsBlocking":false},
{"BackendAction":"Put","BackendPath":"duplicati-bae1dbf3953de426b80a0f51f7cead2b0.dblock.zip.aes","BackendFileSize":10398813,"BackendFileProgress":10398813,"BackendSpeed":-1,"BackendIsBlocking":false},
{"BackendAction":"Put","BackendPath":"duplicati-bbef237781f9644db9005043a79d34063.dblock.zip.aes","BackendFileSize":10426269,"BackendFileProgress":10426269,"BackendSpeed":-1,"BackendIsBlocking":false},
{"BackendAction":"Put","BackendPath":"duplicati-b0ed9c56a74ba4f8184e157ee6f812ff5.dblock.zip.aes","BackendFileSize":10424461,"BackendFileProgress":0,"BackendSpeed":-1,"BackendIsBlocking":false}]}}
Jul 19, 2025 07:36:11.236669000
{"BackendAction":"Put","BackendPath":"duplicati-b0ed9c56a74ba4f8184e157ee6f812ff5.dblock.zip.aes","BackendFileSize":10424461,"BackendFileProgress":10424461,"BackendSpeed":-1,"BackendIsBlocking":false}]}}
Progress jumping by 10 MB in 1.2 seconds between updates on fourth line is the concern.
EDIT 3:
Here’s the speed jumping from -1 to high, trying to look at Wireshark WS updates in gvim:
{"BackendAction":"Put","BackendPath":"duplicati-b58f09e3432b94295a6e318d13d8e18c1.dblock.zip.aes","BackendFileSize":10395693,"BackendFileProgress":0,"BackendSpeed":-1,"BackendIsBlocking":false}
{"BackendAction":"Put","BackendPath":"duplicati-b58f09e3432b94295a6e318d13d8e18c1.dblock.zip.aes","BackendFileSize":10395693,"BackendFileProgress":10395693,"BackendSpeed":3465231,"BackendIsBlocking":false}
This looks like a big BackendFileProgress jump too, which might explain the high speed.
Not too long later, the old-style not ActiveTransfers stats switch to this dblock and speed.
I’m trying to regex-search to exclude 0 and negative 1 speeds (character class [0-9]) and there don’t seem to be any, but this wasn’t a very long run. Job log has 20 files uploaded.
EDIT 4:
Here are the upload speeds from profiling log. Slow speeds are expected on slowed line:
2025-07-19 07:49:58 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.94 MiB in 00:13:56.1408171, 12.17 KiB/s
2025-07-19 07:49:58 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b0ed9c56a74ba4f8184e157ee6f812ff5.dblock.zip.aes (9.94 MiB)
2025-07-19 07:49:58 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i365dba61444149aa9433ea04a370118b.dindex.zip.aes (5.26 KiB)
2025-07-19 07:49:59 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.26 KiB in 00:00:00.8560628, 6.15 KiB/s
2025-07-19 07:49:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i365dba61444149aa9433ea04a370118b.dindex.zip.aes (5.26 KiB)
2025-07-19 07:49:59 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b58f09e3432b94295a6e318d13d8e18c1.dblock.zip.aes (9.91 MiB)
2025-07-19 07:50:14 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.94 MiB in 00:14:22.7669847, 11.80 KiB/s
2025-07-19 07:50:14 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bcabe5c2e4ec04f4e936e70988a88c1db.dblock.zip.aes (9.94 MiB)
2025-07-19 07:50:14 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-id987af04c7ef4a9bbc33ba8593c639be.dindex.zip.aes (5.29 KiB)
2025-07-19 07:50:15 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.29 KiB in 00:00:00.6401123, 8.27 KiB/s
2025-07-19 07:50:15 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id987af04c7ef4a9bbc33ba8593c639be.dindex.zip.aes (5.29 KiB)
2025-07-19 07:50:15 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b1a9c229cb0934e0bae81aa3a7b04436f.dblock.zip.aes (9.93 MiB)
2025-07-19 07:50:16 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.92 MiB in 00:14:24.7568402, 11.74 KiB/s
2025-07-19 07:50:16 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bae1dbf3953de426b80a0f51f7cead2b0.dblock.zip.aes (9.92 MiB)
2025-07-19 07:50:16 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i7f5fdc451e674b5da78956a298084722.dindex.zip.aes (5.34 KiB)
2025-07-19 07:50:17 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.34 KiB in 00:00:00.2258939, 23.64 KiB/s
2025-07-19 07:50:17 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i7f5fdc451e674b5da78956a298084722.dindex.zip.aes (5.34 KiB)
2025-07-19 07:50:17 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b47d4b4fafefa4baab61bd5394cb1f323.dblock.zip.aes (9.96 MiB)
2025-07-19 07:50:39 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.94 MiB in 00:14:36.6198651, 11.61 KiB/s
2025-07-19 07:50:44 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bbef237781f9644db9005043a79d34063.dblock.zip.aes (9.94 MiB)
2025-07-19 07:50:45 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-id1fba847c6d34d2a9b6287bc74e74277.dindex.zip.aes (5.26 KiB)
2025-07-19 07:50:45 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.26 KiB in 00:00:00.7125480, 7.38 KiB/s
2025-07-19 07:50:45 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-id1fba847c6d34d2a9b6287bc74e74277.dindex.zip.aes (5.26 KiB)
2025-07-19 07:50:45 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-b9c52eb988aed4b099f6087562626425f.dblock.zip.aes (9.95 MiB)
2025-07-19 08:05:14 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.96 MiB in 00:14:57.2195339, 11.37 KiB/s
2025-07-19 08:05:14 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b47d4b4fafefa4baab61bd5394cb1f323.dblock.zip.aes (9.96 MiB)
2025-07-19 08:05:14 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i9dd82ce410f0484d948bdf0f94bed2fb.dindex.zip.aes (5.39 KiB)
2025-07-19 08:05:15 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.39 KiB in 00:00:00.2693098, 20.00 KiB/s
2025-07-19 08:05:15 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i9dd82ce410f0484d948bdf0f94bed2fb.dindex.zip.aes (5.39 KiB)
2025-07-19 08:05:15 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-bcd6135f7f73b4f42ab7e6dc6cb05d3b0.dblock.zip.aes (9.41 MiB)
2025-07-19 08:05:15 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.93 MiB in 00:15:00.1713600, 11.30 KiB/s
2025-07-19 08:05:16 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b1a9c229cb0934e0bae81aa3a7b04436f.dblock.zip.aes (9.93 MiB)
2025-07-19 08:05:16 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ifb27e811926047b0993344380f32f2bf.dindex.zip.aes (5.23 KiB)
2025-07-19 08:05:16 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.23 KiB in 00:00:00.5900489, 8.87 KiB/s
2025-07-19 08:05:16 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ifb27e811926047b0993344380f32f2bf.dindex.zip.aes (5.23 KiB)
2025-07-19 08:05:24 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.91 MiB in 00:15:24.5685475, 10.98 KiB/s
2025-07-19 08:05:24 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b58f09e3432b94295a6e318d13d8e18c1.dblock.zip.aes (9.91 MiB)
2025-07-19 08:05:24 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i3dfb29d296e54bdaac8e80d31214fea8.dindex.zip.aes (5.22 KiB)
2025-07-19 08:05:25 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.22 KiB in 00:00:00.7310059, 7.13 KiB/s
2025-07-19 08:05:25 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i3dfb29d296e54bdaac8e80d31214fea8.dindex.zip.aes (5.22 KiB)
2025-07-19 08:06:32 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.95 MiB in 00:15:46.6599872, 10.76 KiB/s
2025-07-19 08:06:32 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-b9c52eb988aed4b099f6087562626425f.dblock.zip.aes (9.95 MiB)
2025-07-19 08:06:32 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-i8c21c1ffa9a349f685bdb299a6e8b8a8.dindex.zip.aes (5.20 KiB)
2025-07-19 08:06:33 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 5.20 KiB in 00:00:00.4784188, 10.87 KiB/s
2025-07-19 08:06:33 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-i8c21c1ffa9a349f685bdb299a6e8b8a8.dindex.zip.aes (5.20 KiB)
2025-07-19 08:08:25 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 9.41 MiB in 00:03:10.2662168, 50.63 KiB/s
2025-07-19 08:08:25 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-bcd6135f7f73b4f42ab7e6dc6cb05d3b0.dblock.zip.aes (9.41 MiB)
2025-07-19 08:08:25 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-ifcd7d761b37f4a6a944f9c611cccbeb1.dindex.zip.aes (58.43 KiB)
2025-07-19 08:08:26 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 58.43 KiB in 00:00:00.7527565, 77.63 KiB/s
2025-07-19 08:08:26 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-ifcd7d761b37f4a6a944f9c611cccbeb1.dindex.zip.aes (58.43 KiB)
2025-07-19 08:08:27 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Started: duplicati-20250719T113116Z.dlist.zip.aes (954.54 KiB)
2025-07-19 08:08:38 -04 - [Profiling-Duplicati.Library.Main.Backend.PutOperation-UploadSpeed]: Uploaded 954.54 KiB in 00:00:10.9171032, 87.44 KiB/s
2025-07-19 08:08:38 -04 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: Put - Completed: duplicati-20250719T113116Z.dlist.zip.aes (954.54 KiB)
EDIT 5:
The above July 19 test was actually on 2.1.1.0 Experimental, which came out on July 17.
I’ve gone back to a full-speed line while waiting for any advice, as slow line was too slow.
