Thanks for your reply.
- It is always the same file, but when I delete this file, it is just another file but the error is the same.
- It worked for a while (“Last successful run: Last Thursday at 7:10 AM”)
- “You are currently running Duplicati - 2.0.2.1_beta_2017-08-01” and I installed it as a service in ubuntu with “sudo systemctl enable duplicati” because I needed root permission for some folders
- No, there is no other process on my /media/nas.
Very strange!
And it get’s even more strange. I disabled the schedule for this job and created a new one working on the same folder (my home folder) but storing into a new backup path and it get’s the same behaviour. How can this be?
This is the log of the new job:
Dec 18, 2017 6:32 AM: Message
Fatal error
System.IO.IOException: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
at Duplicati.Library.Main.BackendManager.Delete (System.String remotename, System.Int64 size, System.Boolean synchronous) [0x0004b] in <118ad25945a24a3991f7b65e7a45ea1e>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x004a8] in <118ad25945a24a3991f7b65e7a45ea1e>:0
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList (Duplicati.Library.Main.BackendManager backend, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Database.LocalDatabase database, Duplicati.Library.Main.IBackendWriter log, System.String protectedfile) [0x00000] in <118ad25945a24a3991f7b65e7a45ea1e>:0
at Duplicati.Library.Main.Operation.BackupHandler.PreBackupVerify (Duplicati.Library.Main.BackendManager backend, System.String protectedfile) [0x00066] in <118ad25945a24a3991f7b65e7a45ea1e>:0
Dec 18, 2017 6:32 AM: Warning
Überwinden eines Fehlers beim Löschen der Datei duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes fehlgeschlagen
System.NullReferenceException: Object reference not set to an instance of an object
at Duplicati.Library.Main.BackendManager.ThreadRun () [0x0036a] in <118ad25945a24a3991f7b65e7a45ea1e>:0
Löschung der Datei fehlgeschlagen duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes, prüfe ob Datei existiert
Dec 18, 2017 6:32 AM: Retry
Operation Delete with file duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes attempt 5 of 5 failed with message: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
Operation Delete with file duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes attempt 4 of 5 failed with message: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
at System.IO.File.Delete (System.String path) [0x00082] in <8f2c484307284b51944a1a13a14c0266>:0
at Duplicati.Library.Backend.File.Delete (System.String remotename) [0x00007] in <597a42d267414b2785d434b5a5f9e510>:0
at Duplicati.Library.Main.BackendManager.DoDelete (Duplicati.Library.Main.BackendManager+FileEntryItem item) [0x0001b] in <118ad25945a24a3991f7b65e7a45ea1e>:0
Operation Delete with file duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes attempt 3 of 5 failed with message: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
Operation Delete with file duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes attempt 2 of 5 failed with message: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
Operation Delete with file duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes attempt 1 of 5 failed with message: Lock violation on path /media/cns-store/duplicati/skoch/duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
Dec 18, 2017 6:26 AM: Message
removing remote file listed as Deleting: duplicati-bccd1ada17f784554a46321916f22ebb9.dblock.zip.aes
keeping protected incomplete remote file listed as Temporary: duplicati-20171216T070727Z.dlist.zip.aes
