Hi there, first thanks to all the devs and enthusiasts that are supporting this software.
I am a newbie and just finished installation.
I tried a test restore, and saw that having the config file makes the restore process start much easier (else duplicati seemed to pop an error if the backup configs, during manual reconstruction, don’t match details during initial setup at a field-by-field level)
Perhaps the installation instructions can advise users to store the backup configuration file somewhere off-system so that in case of total system loss and restores from another system, the config file can be used?
cheers
thisonefella
