Stuck on "verifying backend data", cannot stop
The status bar continually reads “verifying backend data”. If I try to pause or stop the backup process, nothing changes.
If I try to repair database, nothing happens. If I try to recreate database, I get “Failed to delete: The process cannot access the file ‘C:\Users\xxx\AppData\Local\Duplicati\xxx.sqlite’ because it is being used by another process.”
Version: 2.0.4.23_beta_2019-07-14 (though this was also happening on the previous version too).
   17 Jul 2019 11:20: Failed to load assembly C:\Program Files\Duplicati 2\Microsoft.WindowsAzure.Storage.dll, error message: Could not load file or assembly 'Microsoft.Data.Services.Client, Version=5.8.1.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
17 Jul 2019 10:58: Starting - ExecuteReader: SELECT "A"."Hash", "C"."Hash" FROM (SELECT "BlocklistHash"."BlocksetID", "Block"."Hash", * FROM "BlocklistHash","Block" WHERE "BlocklistHash"."Hash" = "Block"."Hash" AND "Block"."VolumeID" = 91144) A, "BlocksetEntry" B, "Block" C WHERE "B"."BlocksetID" = "A"."BlocksetID" AND "B"."Index" >= ("A"."Index" * 3200) AND "B"."Index" < (("A"."Index" + 1) * 3200) AND "C"."ID" = "B"."BlockID" ORDER BY "A"."BlocksetID", "B"."Index"
17 Jul 2019 10:58: ExecuteReader: SELECT DISTINCT "Hash", "Size" FROM "Block" WHERE "VolumeID" = 91144 took 0:00:00:00.001
17 Jul 2019 10:58: Starting - ExecuteReader: SELECT DISTINCT "Hash", "Size" FROM "Block" WHERE "VolumeID" = 91144
17 Jul 2019 10:58: ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (261, "duplicati-ide9c9a5566c241c3b045dd37bc260d56.dindex.zip.aes", "Index", "Temporary", -1, 0, 0); SELECT last_insert_rowid(); took 0:00:00:00.000
17 Jul 2019 10:58: Starting - ExecuteScalarInt64: INSERT INTO "Remotevolume" ("OperationID", "Name", "Type", "State", "Size", "VerificationCount", "DeleteGraceTime") VALUES (261, "duplicati-ide9c9a5566c241c3b045dd37bc260d56.dindex.zip.aes", "Index", "Temporary", -1, 0, 0); SELECT last_insert_rowid();
17 Jul 2019 10:58: Re-creating missing index file for duplicati-b1aba0bd14d7a4d08bb7a6152ba3dc72f.dblock.zip.aes
17 Jul 2019 10:58: Backend event: List - Completed: (83.28 KB)
17 Jul 2019 10:48: Backend event: List - Started: ()
