One day my backup succeeds, the next day it fails with an unexpected difference in fileset 0. I delete the version, run backup and it’s fine. The next backup fails.
Running Duplicati - 2.0.5.1_beta_2020-01-18 on Linux with mono version 6.12.0.107.
I turned on logging and found this:
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/methods.js
Mono.Data.Sqlite.SqliteException (0x80004005): Abort due to constraint violation
UNIQUE constraint failed: FilesetEntry.FilesetID, FilesetEntry.FileID
at Mono.Data.Sqlite.SQLite3.Reset (Mono.Data.Sqlite.SqliteStatement stmt) [0x00084] in <bd1441a78b104a3a92ac102d55be11d3>:0
at Mono.Data.Sqlite.SQLite3.Step (Mono.Data.Sqlite.SqliteStatement stmt) [0x0003d] in <bd1441a78b104a3a92ac102d55be11d3>:0
at Mono.Data.Sqlite.SqliteDataReader.NextResult () [0x00104] in <bd1441a78b104a3a92ac102d55be11d3>:0
at Mono.Data.Sqlite.SqliteDataReader..ctor (Mono.Data.Sqlite.SqliteCommand cmd, System.Data.CommandBehavior behave) [0x0004e] in <bd1441a78b104a3a92ac102d55be11d3>:0
at (wrapper remoting-invoke-with-check) Mono.Data.Sqlite.SqliteDataReader..ctor(Mono.Data.Sqlite.SqliteCommand,System.Data.CommandBehavior)
at Mono.Data.Sqlite.SqliteCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x00006] in <bd1441a78b104a3a92ac102d55be11d3>:0
at Mono.Data.Sqlite.SqliteCommand.ExecuteNonQuery () [0x00000] in <bd1441a78b104a3a92ac102d55be11d3>:0
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery (System.Data.IDbCommand self, System.Boolean writeLog, System.String cmd, System.Object[] values) [0x0005e] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteNonQuery (System.Data.IDbCommand self, System.Boolean writeLog) [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Database.LocalBackupDatabase.AddFile (System.Int64 pathprefixid, System.String filename, System.DateTime lastmodified, System.Int64 blocksetID, System.Int64 metadataID, System.Data.IDbTransaction transaction) [0x00121] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Backup.BackupDatabase+<>c__DisplayClass15_0.<AddFileAsync>b__0 () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner+<>c__DisplayClass3_0.<RunOnMain>b__0 () [0x00000] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Common.SingleRunner.DoRunOnMain[T] (System.Func`1[TResult] method) [0x000b0] in <8f1de655bd1240739a78684d845cecc8>:0
at Duplicati.Library.Main.Operation.Backup.FileBlockProcessor+<>c__DisplayClass1_0.<Run>b__0 (<>f__AnonymousType8`2[<Input>j__TPar,<StreamBlockChannel>j__TPar] self) [0x00681] in <8f1de655bd1240739a78684d845cecc8>:0
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/merge.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/mapKeys.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/mapValues.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/defaults.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/defaultsDeep.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/create.js
2021-02-17 19:05:02 -06 - [Warning-Duplicati.Library.Main.Operation.Backup.FileBlockProcessor.FileEntry-PathProcessingFailed]: Failed to process path: /home/jpschewe/.atom/packages/atom-beautify/node_modules/coffee-fmt/node_modules/lodash/object/keys.js
