Once again, duplicati runs fine, takes time to process files, scans everything, takes long to run, but doesn’t backup files. Even if there are guaranteed changes to be backed up.
It runs fine for several hours and then this error is shown in logs, and the backup isn’t updated. Yet there’s no any other indication about the malfunction. Everything seems to be ok, except the data in the baclkup. I’m sure many might once again completely miss that the backup job is broken, which is very dangerous pattern.
System.IO.FileNotFoundException: Could not load file or assembly 'netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies.
File name: 'netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51'
at Duplicati.Library.Encryption.EncryptionBase.Encrypt (System.IO.Stream input, System.IO.Stream output) [0x00000] in <c709a8649bdf4b8f90a9e36916249677>:0
at Duplicati.Library.Encryption.EncryptionBase.Encrypt (System.String inputfile, System.String outputfile) [0x0000e] in <c709a8649bdf4b8f90a9e36916249677>:0
at Duplicati.Library.Main.Operation.Common.BackendHandler+FileEntryItem.Encrypt (Duplicati.Library.Main.Options options) [0x0003b] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Volumes.VolumeWriterBase.CreateFileEntryForUpload (Duplicati.Library.Main.Options options) [0x00018] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess.UploadVolumeAndIndex (Duplicati.Library.Main.Operation.Backup.SpillVolumeRequest target, CoCoL.IWriteChannel`1[T] outputChannel, Duplicati.Library.Main.Options options, Duplicati.Library.Main.Operation.Backup.BackupDatabase database) [0x00018] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Operation.Backup.SpillCollectorProcess+<>c__DisplayClass0_0.<Run>b__0 (<>f__AnonymousType11`2[<Input>j__TPar,<Output>j__TPar] self) [0x005a2] in <e4ba2224a87c42cbadcd524985619ee3>:0
at CoCoL.AutomationExtensions.RunTask[T] (T channels, System.Func`2[T,TResult] method, System.Boolean catchRetiredExceptions) [0x000d5] in <9a758ff4db6c48d6b3d4d0e5c2adf6d1>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunMainOperation (System.Collections.Generic.IEnumerable`1[T] sources, Duplicati.Library.Snapshots.ISnapshotService snapshot, Duplicati.Library.Snapshots.UsnJournalService journalService, Duplicati.Library.Main.Operation.Backup.BackupDatabase database, Duplicati.Library.Main.Operation.Backup.BackupStatsCollector stats, Duplicati.Library.Main.Options options, Duplicati.Library.Utility.IFilter sourcefilter, Duplicati.Library.Utility.IFilter filter, Duplicati.Library.Main.BackupResults result, Duplicati.Library.Main.Operation.Common.ITaskReader taskreader, System.Int64 filesetid, System.Int64 lastfilesetid, System.Threading.CancellationToken token) [0x0035f] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Operation.BackupHandler.RunAsync (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x01048] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Operation.BackupHandler.Run (System.String[] sources, Duplicati.Library.Utility.IFilter filter, System.Threading.CancellationToken token) [0x00009] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Controller+<>c__DisplayClass14_0.<Backup>b__0 (Duplicati.Library.Main.BackupResults result) [0x0004b] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x0026f] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.Library.Main.Controller.Backup (System.String[] inputsources, Duplicati.Library.Utility.IFilter filter) [0x00074] in <e4ba2224a87c42cbadcd524985619ee3>:0
at Duplicati.CommandLine.Commands.Backup (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Collections.Generic.List`1[T] args, System.Collections.Generic.Dictionary`2[TKey,TValue] options, Duplicati.Library.Utility.IFilter filter) [0x00119] in <89b45aad167a47f49edcb55e6b3d71af>:0
at (wrapper delegate-invoke) System.Func`6[System.IO.TextWriter,System.Action`1[Duplicati.Library.Main.Controller],System.Collections.Generic.List`1[System.String],System.Collections.Generic.Dictionary`2[System.String,System.String],Duplicati.Library.Utility.IFilter,System.Int32].invoke_TResult_T1_T2_T3_T4_T5(System.IO.TextWriter,System.Action`1<Duplicati.Library.Main.Controller>,System.Collections.Generic.List`1<string>,System.Collections.Generic.Dictionary`2<string, string>,Duplicati.Library.Utility.IFilter)
at Duplicati.CommandLine.Program.ParseCommandLine (System.IO.TextWriter outwriter, System.Action`1[T] setup, System.Boolean& verboseErrors, System.String[] args) [0x00342] in <89b45aad167a47f49edcb55e6b3d71af>:0
at Duplicati.CommandLine.Program.RunCommandLine (System.IO.TextWriter outwriter, System.IO.TextWriter errwriter, System.Action`1[T] setup, System.String[] args) [0x00002] in <89b45aad167a47f49edcb55e6b3d71af>:0
I just happened to catch this by change, when checking logs and seeing that there’s something seriously off with the file dates being “backed up”. - Truth is that it looks like it working, but it actually doesn’t.
I have no idea why this is happening, probably related to the update I’ve installed, probably I’ll need to downgrade to some old version.
Platform: Ubuntu 20.04.2 == Mono
Mono JIT compiler version 6.12.0.90 (tarball Fri Sep 4 14:01:23 UTC 2020)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: yes(610)
Suspend: hybrid
GC: sgen (concurrent by default)
Update: Downgrading to 108 version fixed this issue, so it related with the newer versions only. + Mono version information added.
