So, the Recreating Database job is running. Let’s wait and see. But the error is there.
The file exists:
Datentraeger in Laufwerk C: ist Windows Server 2012 R2 x64
Volumeseriennummer: BC17-58EB
Verzeichnis von C:\Program Files\Duplicati 2
20.01.2021 21:56 10.642.432 storj_uplink.dll
1 Datei(en), 10.642.432 Bytes
0 Verzeichnis(se), 62.386.667.520 Bytes frei
More Log:
Wähle eine Protokollierungsstufe aus und sehe dir die Meldungen an während sie erstellt werden:
ExplicitOnly
17. Febr. 2021 13:04: Fehler beim Laden der Assembly C:\Program Files\Duplicati 2\storj_uplink.dll, Fehlermeldung: Im Modul wurde ein Assemblymanifest erwartet. (Ausnahme von HRESULT: 0x80131018)
17. Febr. 2021 12:19: Starting - ExecuteNonQuery: INSERT INTO "BlocksetEntry" ("BlocksetID", "Index", "BlockID") SELECT DISTINCT "H"."BlocksetID", "H"."Index", "H"."BlockID" FROM (SELECT "E"."BlocksetID" AS "BlocksetID", "D"."FullIndex" AS "Index", "F"."ID" AS "BlockID" FROM ( SELECT "E"."BlocksetID", "F"."Index" + ("E"."BlocklistIndex" * 3200) AS "FullIndex", "F"."BlockHash", MIN(102400, "E"."Length" - (("F"."Index" + ("E"."BlocklistIndex" * 3200)) * 102400)) AS "BlockSize", "E"."Hash", "E"."BlocklistSize", "E"."BlocklistHash" FROM ( SELECT * FROM ( SELECT "A"."BlocksetID", "A"."Index" AS "BlocklistIndex", MIN(3200 * 32, ((("B"."Length" + 102400 - 1) / 102400) - ("A"."Index" * (3200))) * 32) AS "BlocklistSize", "A"."Hash" AS "BlocklistHash", "B"."Length" FROM "BlocklistHash" A, "Blockset" B WHERE "B"."ID" = "A"."BlocksetID" ) C, "Block" D WHERE "C"."BlocklistHash" = "D"."Hash" AND "C"."BlocklistSize" = "D"."Size" ) E, "TempBlocklist-0C7A232D71E34A4386E35375C35824A7" F WHERE "F"."BlocklistHash" = "E"."Hash" ORDER BY "E"."BlocksetID", "FullIndex" ) D, "BlocklistHash" E, "Block" F, "Block" G WHERE "D"."BlocksetID" = "E"."BlocksetID" AND "D"."BlocklistHash" = "E"."Hash" AND "D"."BlocklistSize" = "G"."Size" AND "D"."BlocklistHash" = "G"."Hash" AND "D"."Blockhash" = "F"."Hash" AND "D"."BlockSize" = "F"."Size" UNION SELECT "Blockset"."ID" AS "BlocksetID", 0 AS "Index", "Block"."ID" AS "BlockID" FROM "Blockset", "Block", "TempSmalllist-37B44EDD17186844B05ED0A1F27EC478" S WHERE "Blockset"."Fullhash" = "S"."FileHash" AND "S"."BlockHash" = "Block"."Hash" AND "S"."BlockSize" = "Block"."Size" AND "Blockset"."Length" = "S"."BlockSize" AND "Blockset"."Length" <= 102400 ) H WHERE ("H"."BlocksetID" || ':' || "H"."Index") NOT IN (SELECT ("ExistingBlocksetEntries"."BlocksetID" || ':' || "ExistingBlocksetEntries"."Index") FROM "BlocksetEntry" "ExistingBlocksetEntries" )
17. Febr. 2021 12:19: ExecuteNonQuery: INSERT INTO "Block" ("Hash", "Size", "VolumeID") SELECT "FullHash" AS "Hash", "Length" AS "Size", -1 AS "VolumeID" FROM (SELECT "A"."FullHash", "A"."Length", CASE WHEN "B"."Hash" IS NULL THEN '' ELSE "B"."Hash" END AS "Hash", CASE WHEN "B"."Size" is NULL THEN -1 ELSE "B"."Size" END AS "Size" FROM (SELECT DISTINCT "FullHash", "Length" FROM (SELECT "BlockHash" AS "FullHash", "BlockSize" AS "Length" FROM ( SELECT "E"."BlocksetID", "F"."Index" + ("E"."BlocklistIndex" * 3200) AS "FullIndex", "F"."BlockHash", MIN(102400, "E"."Length" - (("F"."Index" + ("E"."BlocklistIndex" * 3200)) * 102400)) AS "BlockSize", "E"."Hash", "E"."BlocklistSize", "E"."BlocklistHash" FROM ( SELECT * FROM ( SELECT "A"."BlocksetID", "A"."Index" AS "BlocklistIndex", MIN(3200 * 32, ((("B"."Length" + 102400 - 1) / 102400) - ("A"."Index" * (3200))) * 32) AS "BlocklistSize", "A"."Hash" AS "BlocklistHash", "B"."Length" FROM "BlocklistHash" A, "Blockset" B WHERE "B"."ID" = "A"."BlocksetID" ) C, "Block" D WHERE "C"."BlocklistHash" = "D"."Hash" AND "C"."BlocklistSize" = "D"."Size" ) E, "TempBlocklist-0C7A232D71E34A4386E35375C35824A7" F WHERE "F"."BlocklistHash" = "E"."Hash" ORDER BY "E"."BlocksetID", "FullIndex" ) UNION SELECT "BlockHash", "BlockSize" FROM "TempSmalllist-37B44EDD17186844B05ED0A1F27EC478" )) A LEFT OUTER JOIN "Block" B ON "B"."Hash" = "A"."FullHash" AND "B"."Size" = "A"."Length" ) WHERE "FullHash" != "Hash" AND "Length" != "Size" took 0:00:13:01.041
17. Febr. 2021 12:06: Starting - ExecuteNonQuery: INSERT INTO "Block" ("Hash", "Size", "VolumeID") SELECT "FullHash" AS "Hash", "Length" AS "Size", -1 AS "VolumeID" FROM (SELECT "A"."FullHash", "A"."Length", CASE WHEN "B"."Hash" IS NULL THEN '' ELSE "B"."Hash" END AS "Hash", CASE WHEN "B"."Size" is NULL THEN -1 ELSE "B"."Size" END AS "Size" FROM (SELECT DISTINCT "FullHash", "Length" FROM (SELECT "BlockHash" AS "FullHash", "BlockSize" AS "Length" FROM ( SELECT "E"."BlocksetID", "F"."Index" + ("E"."BlocklistIndex" * 3200) AS "FullIndex", "F"."BlockHash", MIN(102400, "E"."Length" - (("F"."Index" + ("E"."BlocklistIndex" * 3200)) * 102400)) AS "BlockSize", "E"."Hash", "E"."BlocklistSize", "E"."BlocklistHash" FROM ( SELECT * FROM ( SELECT "A"."BlocksetID", "A"."Index" AS "BlocklistIndex", MIN(3200 * 32, ((("B"."Length" + 102400 - 1) / 102400) - ("A"."Index" * (3200))) * 32) AS "BlocklistSize", "A"."Hash" AS "BlocklistHash", "B"."Length" FROM "BlocklistHash" A, "Blockset" B WHERE "B"."ID" = "A"."BlocksetID" ) C, "Block" D WHERE "C"."BlocklistHash" = "D"."Hash" AND "C"."BlocklistSize" = "D"."Size" ) E, "TempBlocklist-0C7A232D71E34A4386E35375C35824A7" F WHERE "F"."BlocklistHash" = "E"."Hash" ORDER BY "E"."BlocksetID", "FullIndex" ) UNION SELECT "BlockHash", "BlockSize" FROM "TempSmalllist-37B44EDD17186844B05ED0A1F27EC478" )) A LEFT OUTER JOIN "Block" B ON "B"."Hash" = "A"."FullHash" AND "B"."Size" = "A"."Length" ) WHERE "FullHash" != "Hash" AND "Length" != "Size"
17. Febr. 2021 12:06: ExecuteScalarInt64: SELECT COUNT(*) FROM "RemoteVolume" WHERE "State" = "Temporary" AND "Type" = "Blocks" took 0:00:00:00.000
17. Febr. 2021 12:06: Starting - ExecuteScalarInt64: SELECT COUNT(*) FROM "RemoteVolume" WHERE "State" = "Temporary" AND "Type" = "Blocks"
17. Febr. 2021 12:06: CommitRecreatedDb took 0:00:08:06.139
17. Febr. 2021 11:58: Starting - CommitRecreatedDb
17. Febr. 2021 11:58: ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = "duplicati-iffec5e6c12d94fadbdf9ee51612bfd1e.dindex.zip" took 0:00:00:00.000
17. Febr. 2021 11:58: Starting - ExecuteScalarInt64: SELECT "ID" FROM "Remotevolume" WHERE "Name" = "duplicati-iffec5e6c12d94fadbdf9ee51612bfd1e.dindex.zip"
17. Febr. 2021 11:58: ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = "ydISA1qPDVJqZ7kQ9KK3hfbuM++JxO5DMyzKu7ZW/To=" AND "Size" = 102400 took 0:00:00:00.000
17. Febr. 2021 11:58: Starting - ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = "ydISA1qPDVJqZ7kQ9KK3hfbuM++JxO5DMyzKu7ZW/To=" AND "Size" = 102400
17. Febr. 2021 11:58: ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = "OMvX0KURLr4Td/jS2IAxQxkBENaC0JhfmQX0iL9XZvk=" AND "Size" = 102400 took 0:00:00:00.000
17. Febr. 2021 11:58: Starting - ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = "OMvX0KURLr4Td/jS2IAxQxkBENaC0JhfmQX0iL9XZvk=" AND "Size" = 102400
17. Febr. 2021 11:58: ExecuteScalarInt64: SELECT "VolumeID" FROM "Block" WHERE "Hash" = "F8zA8OSwf4CXz3XU9MtAfixoQ3tqngl9EA0w+is4tZg=" AND "Size" = 102400 took 0:00:00:00.000
